603,923 active members*
3,063 visitors online*
Results 1 to 14 of 14
    Feb 2006
    4
    RENCO encoder replacement
    Hi guys;
    I use Renco encoder type RCH20D-2000/3-8-5/0-LD/VC-M6-S for the servo motor, however Renco stop producing this type of encoder, could help to suggest any replace type of eoncoder. The detail data please refer to attached file. In my case, the pin number 8 is a special signal ABS, which use for commutation.
    Tks and with best regards
    York
    Attached Files Attached Files
    Aug 2004
    2849
    Why don't you contact Renco and ask them for a suitable replacement??
    Feb 2006
    4
    However i need to pay Renco 3000USD for retrofit, therefore i search for a new type or brand encoder.
    Aug 2004
    2849
    Okay, well that clears up the confusion....since it's an LD (line driver)....you probably can't use the US Digital Encoders....unless you're willing to use a single-ended encoder....and the servo is a brushless servo??
    Feb 2006
    4
    It is AC brushless servo motor of Electro-Craft type H-4030. In generally, i could find encoder which have normal channel like A/B, Index, u, v, w, however the special signal ABS is not common.
    Jun 2003
    866
    what drive are you using to run these motors? Some of the drives that will work with this series don't need the "abs" track.
    Feb 2006
    4
    Hi Mr. Unterhaus;
    Thank you for your e-mail. the driver is BRU200 of Electro-Craft, for my application, ABS track is must need. Do you have any information about ABS track?
    Jan 2012
    Renco RCH20D Replacements
    Here is EPC's web page Rotary Encoders By Encoder Products Company
    Bill
    Sep 2010
    1765
    contact ur local danaher controls dynapar encoder rep; he can get u a drop in exact replacement for this - it is a common enough encoder.
    I missed also pointing out EPC (Encoder Products Corp) also has drop in replacements for this - Thanks for the reminder EPC Bill!
    Oct 2009
    12
    Hi guys,
    I have every type ranco encorder if you have need contact me ([email protected])
    Dec 2003
    24260
    Quote Originally Posted by Khalid.Ins-Tek View Post
    Hi guys,
    They must be old stock as it looks like Heidenhain has reduced Renco to a shadow of its former self since the take over.
    Under Renco I found it handy as every so often throughout the year they would list their over runs on ebay for 10¢ on the $ .:devious:
    Al.
    Albert E.
    Sep 2010
    1765
    u did see the exact drop in replacement offer, right?
    Quote Originally Posted by yorkma View Post
    Hi guys;
    York
    York, You DID see EPC Bill's reply below that gave you an EXACT drop in replacement model, right???
    What more do you want or need?
    Dec 2003
    24260
    Quote Originally Posted by mike_Kilroy View Post
    Although the answer was 6 years later!
    Hopefully he didn't have to wait that long?
    Al.
    Albert E.
    Sep 2010
    1765
    OMG! AL, i didnt see that! so funny!
