587,189 active members*
3,175 visitors online*
    Feb 2010
    8
    Renishaw Touch Probe
    We are buying an new large Gantry 5-axis for cutting molds. One of the options is an Renishaw Touch Probe. Is it worth it or just an waste of money.
    Feb 2009
    6028
    Probes are nice, especially for castings. They can really help center up rough castings, or even tell weather the casting has enough material to clean up. Downside is, takes a fair amount of macro programming, slows production down if it has to qualify every part, but on the flip side you may not scrap as many parts.
    Apr 2006
    3206
    Depends on how sophisticated you'd like your manufacturing to be.
    If you're talking about the spindle mounted probe, you should consider it for in-process QC, monitoring tool wear, positioning, casting verification, ... etc...
    It will take some time to program, but in my opinion it's worth the expense if you're going to compete.. as long as you use it to its full capabilities...
    ...and your control will accommodate the input and the input into your program in a macro.
    I think a probe for 5 axis work is a great help in locating a part that doesn't have easy reference points...and helping to eliminate tooling balls.
  1. Converting a renishaw touch probe
    By Pplug in forum Techno CNC
    Last Post: 01-12-2014, 01:10 AM
  2. Renishaw touch trigger probe question
    By Shotout in forum Okuma
    Last Post: 02-11-2011, 06:34 PM
  3. renishaw probe tip
    By kwhite2 in forum Haas Mills
    Last Post: 01-11-2011, 12:38 PM
  4. Renishaw touch probe calibration and accuracy
    By gpcoe in forum Haas Mills
    Last Post: 06-29-2010, 09:50 PM
  5. Renishaw Mazak Bore touch off
    By orionstarman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-30-2008, 06:47 AM
