587,561 active members*
3,286 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Replace Internal PRT-E1500W With External - Can It Be Done?
Page 1 of 2 12
Results 1 to 20 of 33
Hybrid View
    Mar 2019
    26
    Last thought before I buy a new machine. Seeing as I can't gain access to the VFD's settings I'm going to call it "stuffed" - a replacement is $150 AUD plus postage from China. After watching numerous youtube videos on wiring VFD's up I had a thought that I may be able to use an external VFD and the PRT-E1500W box just as a controller for the X, Y and Z using Mach3 of course.
    1) Is this at all possible?
    2) Have I missed anything?
    3) Am I wasting my time?
    In the photo of the internals of my box I've circled the wires that would need to be attached to the external VFD. the other photo is the VFD I'm looking at.
    Cheers
    Mar 2007
    2083
    Re: Replace Internal PRT-E1500W With External - Can It Be Done?
    if the breakout board is like this TX14175
    Attachment 416112
    I don't see why not
    the BOB will have a 0-10V analogue output to connect to the new VFD to control the spindle speed
    and a relay to switch the spindle on and off
    John
    Jan 2007
    626
    Probably just as easy to remove the old VFD from the enclosure and fit the new VFD in its place.
    Would be alot neater.
    Mar 2007
    2083
    While fitting the VFD inside the control box is neater
    having the VFD external can reduce the electrical noise from the VFD and its wiring
    from interfering with the low level logic signals from the BOB
    many of the Chinese CNC control boxes have a shock hazard due to the use of a 5 pin plug as the outlet to the spindle motor
    Attachment 416116
    I would either fit a socket on the box or use a strain relief and connect the motors cable directly to the VFD terminals
    also double check the earth wire is connected to the spindle motors case
    very often the 4 pin plug on the motor does not have the 4th pin connected !
    Attachment 416118
    John
    Mar 2019
    26
    Quote Originally Posted by john-100 View Post
    Attachment 416116
    Attachment 416118
    John
    John,
    On the spindle connection inside the box, even though there are 5 pins only three are used. as for the BOB you show, it is like that.
    You've lost me when you mention 'strain relief' (total noob to all this)
    Cheers.
    Jan 2007
    626
    from interfering with the low level logic signals from the BOBJohn
    Agreed. Its a bit catch 22. Electrical noise varies with each VFD. Some are better than others. It certainly may be easier to combat it with the VFD on the outside of the enclosure.
    I was thinking more about safety and neatness of the installation.
    very often the 4 pin plug on the motor does not have the 4th pin connected ! John
    John[/QUOTE]
    Yes, he will find the earth connection missing, probably....
    Very important if something goes wrong....
    Steve
    ericks Guest
    I also agree, if he can he should place his drive in a separate enclosure. However having these drives mounted in the open is a bad idea, i have seen people doing it
    Mar 2007
    2083
    Hi TaffyCarl
    If you did away with the chassis mounted plug and inline socket on the motor cable
    you could use a cable strain relief / gland like this -
    Attachment 416152
    it protects , seals and clamps the cable as it passes through the cnc control enclosure
    the spiral on the end restricts how much the cable bends as it exits the gland
    from another post on cnczone a photo of limit switch cables passing through cable glands
    Attachment 416154
    an initial wiring diagram for a similar cnc machine
    Attachment 416156
    I noticed the crossed 2 wires on the Z axis motor to reverse the direction of the motor so it works with the default mach 3 settings !
    down the right hand side is the spindle motor wiring
    I suspect they use the cheapest cable available so the wire colours are not consistent from one machine to another
    or internal wiring to external cable
    NOTE the novel use of the yellow / green for the VFD V phase to the motor !!!
    John
    ericks Guest
    Sterob gave you the correct/good advise....
    Mar 2019
    26
    Quote Originally Posted by ericks View Post
    I'd do it if I knew what the hell he was talking about LOL - yes I have a multimeter, I use it to check bike batteries that's about the extent of it. Start talking Ohms or "3 phases on the spindle" you've lost me.
    Mar 2019
    26
    Cheers Gent's all info is greatly appreciated.
    After watching numerous Youtube videos (such as the video below). What annoyed me was no real On/Off switch it has to be done at the wall hence my thought of sending main and spindle power through and using the On/Off switch of the semi gutted PRT-E1500W box. I suppose I could do it as most have done and flick the power off at the wall but to me that's an annoyance and untidy.
    I made the jump from an air cooled 3040 which never missed a beat in years of use, to this water cooled 6040 in November 2018 and not used it once because of the faulty box and the fact the seller, and Paypal are d**ks.
    I don't claim to be an electrical wizard, I've been stalling on re-wiring my 1966 Triumph Tiger even though I bought a complete new wiring harness and a workshop manual :-O so bare with me if I come back and ask more (simple?) questions in regards to this VFD setup.
    Cheers again
    Taff
    https://www.youtube.com/watch?v=JWACS6dMMQ0
    Mar 2007
    2083
    if your CNC control box is like this -
    Attachment 416172
    your IEC mains input connector is connected to a 2 pole switch (with red neon indicator) that switches the mains supply to the VFD and the stepper drivers power supply
    it looks like they have used 2 red wires to connect the live and neutral supply to the switch
    and used 2 black wires to connect the switched the live and neutral to the VFD and stepper driver power supply
    John
    Mar 2019
    26
    As a test I ripped the VFD out of the box, isolated any possible live wires, plugged it in and it didn't go bang (bonus for me) but now have no ability to move X, Y or Z via the keyboard or pendant, only via the tab out on Mach3 screen. I can't understand why it doesn't work on the pendant as the E-Stop, spindle speed etc do so it's not the pendant - hmmm odd.
    Update:
    Sorted, Jog was off, turned it on and both the keyboard and pendant now work. The X needed reversing but that's an easy fix - just need to fine tune the set up (moves to slow) when I get the VFD and spindle sorted over the weekend and start attacking scrap board to make sure everything's right.
    ericks Guest
    It's not difficult to do these tests....they should be done before you even power up for the first time
    Jan 2007
    626
    Good stuff..Your on to it.
    Mar 2019
    26
    Ok, the insanity sets in! The VFD turned up today, first set up made the controller box make some weird clicking noises so I scrapped that idea and just connected a power lead direct to the VFD as per the many videos out there. I set the basics to the required 400 and nothing went bang when I turned it on.
    Took the top off the spindle and added the earth as recommended as each time I tried to get it going it gave me an ERR1 which the manual claims is a Short Circuit/Current Overload/Power Module Protection - to that I say "HUH?"
    Took the cable out of the spindle and I don't get the ERR1. Am I looking at a damaged spindle or what? I've swapped the UVW connections around but nothing makes a difference. Attached is supposedly the manual for the VFD - nothing came with this AT1 so I had to hunt it down - just waiting on the seller to see if they have one but not holding my breath.
    Cheers
  17. #17
    ericks Guest
    Have you made any progress??
  18. #18
    Mar 2019
    26
    Yeh, tripped the house safety switch!!
    Watched youtube videos on how to test with a multimeter, I know the meter works so may be the spindle needs to go to an electrician for testing. I ended up buying a new set up, just waiting on its arrival as I've probably killed this one and the cost of a new 1.5 - 2.2Kw W/C spindle and yet another 'supposed' decent VFD is not that far off the cost of a complete system - oh well I end up with a lot of spares and maybe a 6040 frame I can flog off.
  19. #19
    Jan 2007
    626
    Damaged Spindle?.......maybe.
    Got a Multimeter? Measure the resistance between all 3 phases on the spindle. They all should quite low and similar. ( not sure how low. )
    Measure between each phase to earth. They all should be open circuit.
    Not the 'best' way to test motors, but it should give you some clues. One really needs an Insulation Tester to get definitive results.....
    If you DVM results are 'iffy', then testing with a Insulation Tester will be needed to confirm.
  20. #20
    Mar 2007
    2083
    if you have wired it as in the manual
    Attachment 416286
    you can either have a stray strand of wire on a connector shorting a phase to ground
    or the motor has been damaged and the insulation of one or more windings fails when the VFD is powered
    an ordinary multimeter set to ohms will test at too low a voltage
    insulation testers will test the insulation at 250 or 500V
    John
    PS
    the phase to phase resistance for a delta connected motor is around 1.5 to 2 ohms
Page 1 of 2 12
  1. Internal and External Hex Broaching
    By florida in forum News Announcements
    Last Post: 05-16-2013, 10:54 PM
  2. Internal and External threading on HF 7 x 10
    By mthompson239 in forum Mini Lathe
    Last Post: 04-12-2013, 07:52 PM
  3. internal and external thread macro
    By frigat76 in forum Fanuc
    Last Post: 10-27-2011, 11:08 PM
  4. Can EMC update its internal X,Y,Z according to an external reading?
    By david_geng in forum LinuxCNC (formerly EMC2)
    Last Post: 11-07-2007, 05:19 AM
  5. Method to internal/external thread ?
    By PeteGallo in forum Uncategorised CAM Discussion
    Last Post: 04-03-2007, 03:50 PM
