603,807 active members*
2,694 visitors online*
    Feb 2007
    54
    Replacing ball bearings on INA linear rails
    Anyone familiar with the process of replacing the ball bearings on INA linear rails? similar to THK or HIWN
    Why are you replacing them? You can buy precision balls in almost any size. Do you know the size of the balls? Actually replacing them shouldn't be to difficult other than chasing tiny balls around the workbench.
    Feb 2007
    54
    Well I bit the bullet and took one bearing apart allready....it was easy except chasing the tiny things around the bench...
    I bought used rails and cleaning and greasing them didn't work so I figured I would "fix" it...
    That is what was needed and I will be ordering some more ball bearings...one is actually missing a few
  1. replacing ball bearings INA linear rails
    By roger_e in forum Linear and Rotary Motion
    Last Post: 03-11-2010, 09:29 PM
  2. Glacern Supported Linear Rails & Bearings
    By Glacern in forum Linear and Rotary Motion
    Last Post: 02-12-2010, 07:35 PM
  3. Linear Rails and Bearings
    By Robyn in forum News Announcements
    Last Post: 08-30-2006, 04:10 PM
  4. Linear Rails/guides and Bearings - What size is best?
    By Shawnusa in forum Linear and Rotary Motion
    Last Post: 10-29-2005, 04:51 PM
  5. Linear rails and bearings- overkill?
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 01-30-2004, 10:43 AM
