Hi ,
I have a manual milling machine (PM25) that I recently converted to CNC.
I would like to controll the Spindle from the PC instead of manually with the speed control Potentiometer on the mills controll box.
I would like to use the existing spindle control board that came with the manual mill.
I was thinking of replacing the potentiometer that controlls the spindle speed with the analog output of my breakout board(0-5V).
(I verified that the manual potentiometer signal is between 0-5v)
However I am worried about connecting the Ground from my breakout board to the ground of the Spindle control board.
It seems to me that both grounds do not necessarily have the same potential.
My Question:
What is the best way to replace a potentiometer with a PWM controlled analog output (without the ground issue)?
Can anyone recoomend a PWM board that is optically isolated?
My breakout board is : the chines ST-v2 board (see attached pictureAttachment 395722)
My Spindle controll board is: spindle control board that ships with the PM25 milling machine
