603,963 active members*
3,212 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Request. Convert SolidModel (Solidworks) into Mastercam
Results 1 to 9 of 9
    Oct 2007
    3
    My CNC guy for some reason cannot open the solidworks file into mastercam. Can someone here PM me and convert a solid model into Mastercam for me? I need it pretty fast. Thank you.
    Feb 2007
    156
    Use the parasolids file converter, file to open or in the list change from .x_t to .sld
    Or, just output the solidworks file to a parasolid file.
    Dave
    Schneider Machine
    A force of one
    Oct 2007
    3
    Quote Originally Posted by Dave1 View Post
    Dave
    Thank you Dave, but I don't have any CNC software myself. Is the parasolids converter a standalone product I could download and use?
    Feb 2007
    156
    It is included in Mastercam, if your cnc guy has Mastercam then he has the converter already. Solidworks should be able to export Parasolids also. Sometimes Mastercam has a problem converting Solidworks files but I think it's a version issue more than anything. I've never had a problem converting a Parasolids file.
    Dave
    Schneider Machine
    A force of one
    Oct 2007
    3
    Dave
    Thanks Dave. I got Rhinocerous to convert it to the parasolids. Looks like it will work. Thanks again Dave. Kudos to you.
    Feb 2007
    156
    Glad to be of assistance
    Dave
    Schneider Machine
    A force of one
    Jul 2007
    195
    If your guy does not have solids with his mastercam software have the solidworks driver save the file as an .igs file from solidworks. Then it can be imported into Mastercam as a surfaced 3D model.
    Be carefull what you wish for, you might get it.
    Feb 2007
    156
    To save an .igs file from Solidworks you first need to check both wireframe and surfaces or it will default to only surfaces. You don't need Mastercam solids to read a Parasolids file, only to write a Parasolids file.
    Dave
    Schneider Machine
    A force of one
    Jan 2007
    24
    I've had to do this many times before. If the .igs file doesn't work save the files as a ProE file. I've had luck when I couldn't get the .igs or Solidworks file to be read using ProE files. It will export as a solid model that even older MasterCAM versions should be able to read.
  1. Solidworks to Mastercam (greenhorn)
    By skydivebase in forum Solidworks
    Last Post: 08-01-2007, 01:26 AM
  2. SolidCAM & Solidworks vs. MasterCAM
    By griffithbuilt in forum Uncategorised CAM Discussion
    Last Post: 07-03-2007, 06:46 PM
  3. How do I convert an autocad 2d to solidworks 3d
    By CuttersCov in forum Solidworks
    Last Post: 03-10-2007, 11:32 PM
  4. MasterCam or SolidWorks ?
    By cijunet in forum Mastercam
    Last Post: 12-19-2006, 09:24 PM
  5. SolidWorks plans request
    By gareth in forum DIY CNC Router Table Machines
    Last Post: 01-26-2005, 04:31 PM
