Now that I've got my software running properly, I've stumbled another issue. When the software boots up it the reset button is flashing and I get a message that a limit switch is triggered or an e stop has been pressed. The thing is I've checked my proximity sensors, they all are working properly and none are trigged when this error comes up. I don't have an E stop set up yet either, I've even removed the pin I've assigned it to in the software until everything is running. When I look at the diagnostics page it indicates that a hard limit has been triggered, although I'm not sure how. I've tried setting the limits as active high and low but that doesn't help. I can see the virtual LEDs turning on or off when I manually trigger a limit switch, so I assume that everything else is working properly. Attachment 344166
Has anyone dealt with this before or have any ideas of what else I should test to troubleshoot this?
