I have a machine using CT Dynamax, Dynamax MS motors and Max 200 drives. I need to convert it to use encoders due to part availibility problems. Has anyone here done this and do you possibly have some information I can use to do the same..
My Max drives use a 16 bit converter card to convert the resolver signal to an encoder signal anyway but I am unable to get the old manufacturer to release any specs on the equipment such as pulses per minute..
Any info at all would be appreciated.
