Hi Fella's
Iv'e just completed the build stage of my router, Its dimensions are 1500 X 1500 using wiscarver linear bearings and 5mm pitch ball screws. I'm using RTA HGD Drives at 50v 6 amps, 3.5Nm 34 frame steppers.The Y-axis uses two srews coupled to one stepper in the middle and has no problems but the X-axis Stepper is directly coupled to the lead screw. When doing an arc there is an chatter at the identical spot and same very low feed each time. Im running Mach2 and I have tried everything. I realise that this is more than likely a resonance problem , what can I do.
Jono.
