603,546 active members*
3,949 visitors online*
    Mar 2008
    75
    Restart program for automatic running
    I want to run a program over and over without pressing the start button every time. I looked for a M code but cant find one. I thought there was one that just replaced M30. If anyone can help that would be great.
    Tom
    Oct 2010
    156
    Re: Restart program for automatic running
    Hi Tom,
    This is one way I do it. On a line just before the start of the code I want to repeat, I put a:
    o100 repeat
    (that is the letter "O" and a one hundred. It doesn't have to be 100, but just needs to be the same as the following line):
    ...and on the line following the end of the code to be repeated, I put:
    o100 endrepeat
    Also, if you know how many times you want it to repeat, you could make that first line "o100 repeat [5]" to make it repeat five times. So, something like this:
    o101 repeat
    G00 X1.000 Y1.000
    G01 X0.000 Y0.000 F100
    o101 endrepeat
    or to repeat 15 times:
    o101 repeat [15]
    G00 X1.000 Y1.000
    o101 endrepeat
    HTH
    Paul
  1. Program restart
    By hotiron in forum CNC Machine Related Electronics
    Last Post: 09-02-2014, 10:29 PM
  2. Restart in mid program
    By Praymond1209 in forum Machines running Mach Software
    Last Post: 09-09-2012, 11:57 PM
  3. Program Restart
    By DocRay in forum Daewoo/Doosan
    Last Post: 12-15-2009, 11:13 PM
  4. Program restart
    By johnd in forum Mach Mill
    Last Post: 03-02-2009, 03:32 AM
  5. M2: program restart eia/iso
    By apylus444 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-07-2008, 01:07 AM
