603,967 active members*
1,918 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Restart with sub programs
Results 1 to 7 of 7
    Mar 2008
    7
    Anyone know how to restart to a specific sequence number that is in a sub program that is called 4 different places?
    Thanks for any help.
    Phil
    Apr 2006
    825
    Easy!
    If you want to restart on the third occurance of line N340 for example... press the restart key and key in N340,3
    This tells the machine to search for the 3rd occurance of N340!
    Hope this helps.
    Cheers
    Brian.
    Mar 2008
    7
    Thanks for the quick reply, I guess I was to lazy to look it up in the manual.
    Mar 2008
    28
    Phil,
    You can also restart by sequence number, it's the number in the upper right corner of the control. The process would go: Auto, extend, restart, (process number), write. Obviously you'll want to be in single block and have the coolant off when you hit sequence restart.
    Apr 2006
    825
    Sequence number restart would only be applicable if you know "Exactly" where you want to restart from! For example, mid way through a roughing cycle or drilling cycle...
    If you have finished the program, or stopped the program for some other reason, and you have gone past the point of restart in program execution, then the sequence number is useless!
    If you find the line number in edit mode, you need to know how to restart on the desired line, thus the ",x" solution where x is the number of times to count the line number before Restarting!
    Jan 2007
    71
    We use labels for that reason. I think that is one of the coolest features of the OSP control, the ability to call processes, NDR1A(drill #1, first use), etc. The guys on the floor loved this idea in that they could search based on this.
    You CAN do anything, if you REALLY want to, but how many people really want to?
    Kyle
    Quote Originally Posted by broby View Post
    Easy!
    Hope this helps.
    Cheers
    Brian.
    Nice trick man!
  1. mach3 plasma restart mid-job?
    By johnt in forum Mach Plasma / Laser
    Last Post: 12-04-2007, 05:59 AM
  2. Mid program restart
    By HuFlungDung in forum Haas Mills
    Last Post: 06-26-2007, 10:32 PM
  3. Restart of integrex eia program with dual turrets
    By Bobc007 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-02-2007, 01:43 AM
  4. Controller Restart problem!
    By VB IT in forum CNC Machine Related Electronics
    Last Post: 02-25-2007, 09:48 AM
  5. haas floppy dnc restart
    By bytecolor in forum Haas Mills
    Last Post: 10-19-2006, 01:31 PM
