Does anyone know where Bbobcad stores it's temp drawings for the 'restore file' function on load up? I remember Sorrin from the training classes brought it up once but I don't remember much on how. Thanks -Jeff
In Win9x, older versions of Bobcad used to store directly into Windows/Temp.
In the more modern version of windows, it will likely be worth checking in your own temp folder, found under Documents and Settings/your username/local settings/temp.
BTW, you won't see this folder unless you have hidden files and folders set to show up in your advanced settings found under Folder options/view in windows explorer.
First you get good, then you get fast. Then grouchiness sets in.
