Hi, newbie here with only a couple weeks under my belt on my DIY CNC router. I've figured out quite a bit about EMC2, and have it running my rig pretty well, but still have a lot of learning/refinement to go yet.
I'm trying to determine if it is possible to resume a job after interrupting it and powering down/rebooting everything. For instance, to support a long photo carving session may need to span multiple evenings and I don't want to leave everything powered on while I'm not around it.
I don't yet have home/limit switches, so I manually home X&Y to a convenient spot and Z to the bed. Then I touch off the X,Y,Z axes to the material. Is this the best way to prep for a job?
I know there is a setting to save the home settings between sessions, does it also save the touch-off settings? If so, my thoughts are to pause or stop the job, note the line #, power off the router/not moving it, close EMC2, power down, leaving material in place, power up, start EMC2, load the .ngc file, scroll to the noted line, power up the router, and restart at or a line or so before that line. I also would like to do this for multi-file jobs, starting the next file on another day.
Thanks,
Roy
