588,066 active members*
5,020 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Retrieve programs from auto buffer.
Results 1 to 6 of 6
    Sep 2012
    Hello.
    I was running a program on my OSP P200L, and while this program was running, i sat down to do some edit on another program.
    The problem is that i accidently overwrited the running program.
    And before I saw this, I was transfering it to the control.
    And now, I have my program in the buffer, and the wrong one in MD1.
    Are there any possibillity to retrieve the program or find it any place, or must I start all over again?
    Aug 2011
    2517
    I don't know a way to backup the program in the buffer but you can read it on the screen and scroll it and write it down on paper then type it in again. if it's not a complicated program it's quicker to re-write it from scratch using IGF or CAM software.
    Apr 2006
    825
    I wonder that since it is a P200 control system, could you possibly copy and paste from the main screen using windows commands to copy the currently running program text into another file?
    Might be able to scroll down one page at a time and copy / paste each screen load...?
    Just a thought, nothing to lose by giving it a shot!
    Cheers
    Brian.
    Aug 2011
    2517
    I don't think there's an easy way to access the CNC program screen from Windows.
    The copy/paste may be available in edit mode but there is no stored program to edit.
    Apr 2006
    825
    Yep, without going out to the machine to try it, I would imagine that you are correct.
    Usually once a program is deleted or overwritten as described above, you are screwed.
    Aug 2011
    2517
    I suppose you could screen capture each page then run it through OCR if you were desperate. Acrobat X Pro does a really nice job of converting a graphic scan (or photo of text) to searchable text.
    But I still say it's easier to scroll the program manually in memory mode and write it down on paper then type it back in if it's only a few screens.
  1. Auto transfer of Programs from PC to CNC
    By vivu91 in forum Fanuc
    Last Post: 07-27-2012, 06:51 AM
  2. Replies: 3
    Last Post: 07-21-2012, 12:21 PM
  3. Retrieve machining time macro
    By Thomas Mantz. in forum UG NX
    Last Post: 05-11-2012, 02:15 PM
  4. buffer overflow
    By wildhorsemfg in forum Fanuc
    Last Post: 09-19-2010, 09:45 AM
  5. Sending Programs with auto-offset adjuster
    By Mythics in forum DNC Problems and Solutions
    Last Post: 12-07-2007, 06:27 PM
