588,261 active members*
5,107 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > RETROFIT OF RADIAL DRILL MACHINE INTO CNC MILL
Page 2 of 3 123
Results 21 to 40 of 59
  1. #21
    Dec 2005
    112
    Khalid,
    It was really exciting to see this project live at your place. It's a nice spindle head you have put together. I am specially interested in it's performance and also the z-axis with linear slides, ball screw, servo motor and all. Let's hope you get enough extra time to finish it up.
    Zafar
  2. #22
    Apr 2006
    3498
    Some Updates
    Here is the short video of the assembled column.
    [nomedia="http://www.youtube.com/watch?v=nevfUvtlu34"]YouTube - Radial Drill Conversion.flv[/nomedia]
    Attached Thumbnails Attached Thumbnails column counterweight.jpg   column.jpg   counterweight.jpg   Radial1.jpg
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  3. #23
    Dec 2005
    112
    Very impressive! The spindle motor looks small for a spindle this size. What is it's power rating?
  4. #24
    Apr 2006
    3498
    Hi Zafar,
    Thanks for the feedback on youtube and here...
    1- Last day i was taking with my fellow for replacing the gears with tooth belt and pulleys... Unfortunately, we didn't found the belt in our locality..I think you will help me in this... I will require a tooth belt from you, We can machine the pulleys here. Can you send me the belt?.. i will give you the size of both gears so that you can judge the belt dimension.
    2- I think the spindle Motor is 3 phase 2.5KW.. We will see if it can work with the setup, the VFD and a single-belt reduction will be used... We intend to machine small parts on this machine and later will see how can we improve the whole setup... The limit and home switches are still not installed yet...
    This is the machine for which i require from you the control panel and control box and help.
  5. #25
    Dec 2005
    112
    Khalid,
    Try Precision Mechanical Components Timing Belts Pulleys Spur Gears Couplings Bearings Sprockets Retaining Rings Brakes Helical Gears Clutches Universal Joints for calculation of belt size based on your center distance and motor power rating. Pass on the required size to me and I'll get the belt for you.
    Zafar
  6. #26
    Apr 2006
    3498
    I will soon give you the details of the required Belt. thanks for the link.
    Attached Thumbnails Attached Thumbnails closeup.jpg   closeup1.jpg   assembled.jpg
  7. #27
    Apr 2006
    3498
    Here is the 90% completed machine
  8. #28
    Apr 2006
    3498
    duplicate post
  9. #29
    Dec 2005
    112
    Looking very impressive. You'll need to cover the y-axis slide to shield it from metal chips. A flexible sheet cover would be ok. That will also cover the y-axis motor from coolant splashes. Hope to see it in action when I visit you two weeks from now. What tool holder are you going to use for it. If you need one then I can get it for you from here.
    Zafar
  10. #30
    Apr 2006
    3498
    Quote Originally Posted by zafarsalam View Post
    Zafar
    Dear Zafar, (I am eagerly waiting for you to get the Servo experience)
    We have yet to install protection covers on motors and slides. The spindle is hardened MK5 taper and all of the tools including the Boring head of our Universal Boring Machine can fit into it.
    I am really interested in Tapping/Threading Cycles on this machine. I hope with the VFD it shall be possible.
    Regards
  11. #31
    Dec 2005
    112
    For tapping you'll need a tapping head like this one. [ame=http://www.youtube.com/watch?v=ou9o-aUqAUI]Tapmatic tapping head - YouTube[/ame]. External threads and large diameter internal threads can be done with helical milling with a single point boring type tool.
  12. #32
    Apr 2006
    3498
    Yes i know about such tapping head tools but i was rather interested in helical tool-paths with single point tools. VisualMill can do threading using helical toolpaths. i am also interested in Rigid Tapping, but it needs very precise control of Spindle motor.
  13. #33
    Dec 2005
    112
    Ok. Get a single point tool ready. We'll do a helical toolpath thread as test job on your machine. I do my g-code programming on Mastercam. Thread milling is very easy with it.
    Zafar
  14. #34
    Apr 2006
    3498
    Okay.. I got three proximity switches today?..I think you will use Soft Limits as Limit Switches and these three shall be used as homing switches?.. These have small length of wires , will you connect additional wires?
    Can you post the pictures of Control Panel and electronics Box?
  15. #35
    Dec 2005
    112
    We can either use the three switches as both home and limit switches or use them as home and employ soft limits. You can terminate the cables of these switches in a small box on the machine body. These switches will be used in parallel and send a single signal to Mach3. So a single cable from the terminal box to the main panel would be sufficient. We are going to use the index pulse from motor encoders for homing which will give us very accurate position and repeatability.
    The panel box is at the powder coating shop. We'll get it back in 3 days.
    Zafar
  16. #36
    Jul 2003
    1760
    with linuxcnc - you can do rigid tapping. (you do not need precise control of the spindle) You need a spindle encoder with index (a,b and z channels).
    linuxcnc 'gears' the axis with the spindle.
    This was all done with just the printer port.
    [ame=http://www.youtube.com/watch?v=C740zS9R9kk&feature=plcp&context=C3bf13adU DOEgsToPDskJ1C-st1DVqOjzou8-cClGS]Rigid Tapping M3X 5 750rpm - YouTube[/ame]
    sam
    Quote Originally Posted by Khalid View Post
  17. #37
    Feb 2010
    331
    how exactly was this accomplished? where can i find more info?
  18. #38
    Jul 2003
    1760
    what kind of info are you looking for? In the simplest form - you need 3 inputs open to read the encoder. within emc you virtually hook up a few pins that connects the encoder to the guts of emc. If you are using the printer port for reading the encoder - you are limited by how fast the computer can count. Say you have a 100 line encoder on the spinde (400 quadrature) on decent computer hardware you should be able to count into the 20-40khz range. so - you should be able to count up to the 3000 - 6000rpm. As long as the axis can keep up with the spindle reversal - you are golden.
    There is a lot of cheap interface hardware out there for emc that will move the encoder counting and pwm outside of the computer which doesn't tax the computer.
    sam
    Quote Originally Posted by Zygoat View Post
  19. #39
    Feb 2010
    331
    Quote Originally Posted by samco View Post
    sam
    do you have any links to such hardware?
    thanks for your help.
  20. #40
    Jul 2003
    1760
    LinuxCNC Documentation Wiki: LinuxCNC Supported Hardware
    mesa and pico are probably the most popular. I am using mesa hardware and love it. Have a look at the 5i25 - it his mesa's latest pci card that has a bunch of options.
    sam
Page 2 of 3 123
  1. Direct Drive Vs Belt Drive for a Mill/Drill Retrofit?
    By pfeist in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2012, 09:12 AM
  2. Anyone in the East Tennessee area doing a mill drill retrofit.....
    By pete from TN in forum Benchtop Machines
    Last Post: 05-04-2008, 02:00 PM
  3. Yoshida Radial Arm Drill Press
    By jnsane84 in forum Uncategorised MetalWorking Machines
    Last Post: 02-07-2008, 08:31 PM
  4. Where to begin? Retrofit a Stepper Control to a Mill-Drill?
    Last Post: 05-04-2004, 11:44 PM
  5. CNC retrofit for Mill/drill?
    By Jkier in forum Uncategorised MetalWorking Machines
    Last Post: 07-04-2003, 12:42 AM
