Looking for help. The problem is: old burned machine that i bought without dongle & software, based on MPC6515 Leetro, dim 1200x900, 80W PSU, X,Y drivers 2X yako yka2304me, Z drivers 2X leedshine m542-05 and it has to be repaired. I am thinking to buy MPC 6525A (as simplest choice for installation) including software, dongle etc. Leetro informed me that I need syscfg.ini fajl (which I haven't) from original LaserCut and then the changes will be easy ( "It could be a easy job for retrofitting if you still keep the installed LaserCut for your MPC6515 in your computer hard disk drive. A file name syscfg.ini is in the installed LaserCut. If you have not that, the setting could be a challenge for both you and Leetro. Leetro does not make whole machine. The LaserCut setting requires the specific specifications of each parts setting.")
If i find similar syscfg.ini file can I implement these one (copy/paste)? Is this file has to be unpacked from LaserCuter installation file or it can be simply changed?
Once I installed controller i will search for other problems in my old burned machine (probably some driver/stepper has to be changed).
Any one some suggestions about these?
Also, i am using one Laser Cutter based at Googol PC card (improved with RECI tube @90W) and one powered by Mach (old tube @ 60W only for cutting) so if any need help from me looking forward to help.
