603,771 active members*
2,845 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Revamping/upgrading old engraving machine
Results 1 to 7 of 7
    Smile Revamping/upgrading old engraving machine
    Hi all!
    So about a year and a half ago now I offered to rebuild an old broken down engraving machine my dad had at his company. It's a New Hermes Vanguard V3400. It's huge, and heavy, and slow. It's pictured below.
    He gave it to me with a blown out motion controller. The PC it came with still functioned, but neither of us were intent on keeping that. I brought it back to life with an Arduino, some stepper controllers, the original power supply from the motion controller, and a Raspberry Pi for the user control, with some nice free software for doing his engraving. It took awhile but I got it done. But then... his company went bust before I was quite ready to hand it over.
    So now I'm stuck with an engraving machine that's not much use to me. What would be of use to me, however, is a full-blown CNC. I'd love to be able to build brackets from aluminum and wood, and mill out PCBs for other projects I work on. I did a few upgrades so far, my dad sent me new X and Y axis screws that he found in a box at his company, and I bought a couple 2.8 amp NEMA 23 motors. I have a few questions though.
    First, he axes are lead screws, and the nuts are entirely plastic. If I wanted to, say, mill out pieces of aluminum, would the lead screw fail? Would it be relatively easy to upgrade to a ball screw?
    Another thing. The spindle motor is in the CNC housing, and a series of belts connect it to the spindle. The belt doesn't feel very tight and it runs at a fixed, high RPM, for engraving. The big question I have is, will I need to get rid of the belt drive and mount the spindle motor on the Z axis, or can I keep it the way it is?
    Lastly, GRBL. What is the consensus on it in the community? Now that I'm not limited by my dad's requirements I'm tempted to purchase a proper motion controller, but GRBL did seem to work alright for engraving. What do other people like to use?
    I do apologize if there's write-ups on all this that I'm not missing. I'm no CNC expert, in fact when I started this project I barely even knew what the acronym stood for. But any guidance would be greatly appreciated.
    Oct 2004
    94
    Re: Revamping/upgrading old engraving machine
    Shouldn't this thread go back into the CNC router forum?
    Quote Originally Posted by Arjay View Post
    Yeah I don't understand why it's not considered DIY, the only thing I haven't changed on this machine is the case and lead screws and spindle...
    Oct 2004
    94
    Quote Originally Posted by katemonster View Post
    I suspect it's because the post started out with the word "engraver." Moderators, please move to the cnc router forum.
    Sep 2005
    171
    I have one like this that I modified also. used the original power supply and the stepper driver for years, but recently changed those out also. I also removed the spindle motor and mounted a RC Outdrive motor, meant for RC airplane. Works great.
    Jul 2024
    10
    I have new and used parts for the 3000 and 3200.
    Jul 2024
    10
    I have used these machines for over 20 years. I may be able to answer questions or provide schematics.
  1. My DYNA-MYTE 3000 Revamping
    By turbina in forum Dyna Mechtronics
    Last Post: 11-19-2024, 04:03 PM
  2. Upgrading a Standard machine to Pro
    By nlancaster in forum Avid CNC
    Last Post: 10-31-2018, 06:01 PM
  3. Replies: 1
    Last Post: 05-28-2013, 01:17 PM
  4. Upgrading dos machine
    By alan.styer in forum Commercial CNC Wood Routers
    Last Post: 06-12-2011, 02:36 PM
