603,946 active members*
2,236 visitors online*
Results 1 to 6 of 6
    Reverse axis direction?
    I posted this in the Xylotex forum, then decided that I was in the wrong place
    So anyway, I have a new Xylotex controller and steppers and I'm running Mach3. The Xylotex setup was their plug-and-play system so all I had to do was plug it together. Well, the Z axis runs backward. I'm not that good with Mach3 (kinda new to CNC altogether) so I don't know if this is a configurable issue - I mean, can I just go somewhere in Mach3 and tell it to reverse one of the axes?
    Thanks,
    Mark
    Mar 2006
    1625
    You may have reversed the polarity to stepper or the signal to controller
    It's just plug-and-play. Xylotex wired it and all you have to do is plug the plugs together. I hope they didn't do it backward?
    Is it possible to tell Mach3 to run that axis in reverse?
    Mar 2003
    35494
    Ports and Pins > Motor OUtputs > Dir ActLow
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Oct 2005
    225
    And if that does not work you can try this. config _ homing/limits and then just click on reversed for the axes you want to reverse.
    Tommy
    (southernexplore)
    Thanks for all of the help - lots of ways to deal with this, huh?
    Thanks,
    Mark
