588,522 active members*
7,805 visitors online*
    Sep 2007
    64
    Reverse direction?
    Hello,
    I am currently using ACE converter to convert my autocad files to g-code. I am milling 1/4 ABS plastic and I noticed that my milled parts come out very rough on the part side but very smooth on the leftover ABS material. I believe that this is due to the rotation direction of the bit and the actual direction that my mill travels.
    What I would like to do is reverse my cut direction but the only options I see in ACE is the ability to reverse the arc direction from clockwise to counterclockwise. How can I reverse the path my mill takes so that I get the smooth edges I am looking for?
    Phil
    Mar 2003
    35538
    Try drawing the lines in the direction you want them cut, and don't let ACE optimize the code.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2007
    64
    Is that the only way? I have my CAD drawings already done and Id hate to have to re-do them. Is there another g-code converter that will do this? Seems to me that this would be fairly common. Thanks.
  1. Reverse
    By frankg521 in forum Mach Mill
    Last Post: 08-06-2007, 03:08 AM
  2. Reverse?
    By UKRobotics in forum Uncategorised MetalWorking Machines
    Last Post: 09-12-2006, 12:20 AM
  3. Reverse CNC
    By adwsystems in forum Uncategorised CAM Discussion
    Last Post: 05-16-2006, 01:05 PM
  4. Reverse axis direction?
    By saturnnights in forum Machines running Mach Software
    Last Post: 03-29-2006, 03:40 AM
  5. my DIY CNC progress in reverse
    By slp_prlzys in forum DIY CNC Router Table Machines
    Last Post: 11-15-2004, 06:44 AM
