What about manual programming the thread? Is this possible? And how would it look like?
Macro?
Macro?
Don't know if this helps, but we had the same problem with radial tapping on an Okuma LB25 lathe. Fortunately, the control has a turret parameter screen which controls the direction of the live tools.
Radial tooling is geared to run opposite of the live tooling spindle. So, to have the tool run clockwise, the live spindle must run counter-clockwise. The least significant bit of the turret parameter byte must be set to "1" for this to happen.
With the bit set, an M13 (live tool clockwise command) actually causes the live spindle to run counter-clockwise, and the radial tool runs clockwise.
You won't believe how many drills have been destroyed by operators that forgot to clear the bit when switching to a straight (axial) holder
Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
Know the problem Had this on a mori lathe, this one doesn't have this option.
What i was thinking was to take a look at the G88 macro, maybe copy it and create my own where spindle go M04 in and M03 out.
For some reason i can't access the O9000 programs, i have done it exactly like manual says, parameter write = 1 3202 bit 4 = 0.
I still can't see the programs in my list.
Missing something?
3202.0 is for the 8000 range. You asked for the 9000 range programs. This is 3202.4
Stevo
Check parameter 57 bit 6. it needs to be a 1 if it is 0 can cycles are only in the Z axis.( "The drilling axis in a fixed cycle is the axis selected by a program" ) Then you need to use G17,G18, or G19 for what plane that you want to tap. Have had to do a few machines to use right angle head attachments.
Hope this helps.
