588,134 active members*
5,440 visitors online*
IndustryArena Forum > CAM Software > Mastercam > reversing toolpaths on surface contour
Results 1 to 9 of 9
    Aug 2009
    55
    Hi, I have a huge amount of parts I need to cut out of one sheet, and I would rather not go through and do contour toolpaths for each one. I can use surface contour and get the whole thing done in a couple clicks (i have all the parts in 3D), however I need to have the CNC cut in a certain direction so I don't get melted plastic on the cut. Can I reverse the chains somehow on a surface contour, or is there a configuration for cutting a certain direction?
    Dec 2009
    80
    Hi, can you post your MC file?
    Aug 2009
    55
    The file is too large to upload here. It is 6.81 mb
    Dec 2009
    80
    Are you using X4 or older version?
    Aug 2009
    55
    Just MasterCam X
    Aug 2009
    55
    does anyone know how to do this in master cam X?
    Dec 2009
    80
    Hi, I´m not sure about which toolpath type you are using but I guess it´s "Surface Finish Contour". If that´s the case you can reverse the direction of the toolpath under the tab "Finish contour parameters" by switching between "Climb" and "Conventional". See picture..
    Aug 2009
    55
    Cool, I never knew what that meant. It works perfectly! Thank You.
    Dec 2009
    80
    You´re welcome, actually, it feels great to bring some help to other people, sooner or later I will need help myself and this is a good place to get it. Good luck with your milling, greetings from a very cold Sweden. /Thomas
  1. Surface pocket toolpaths
    By jcnewbie in forum Mastercam
    Last Post: 10-24-2009, 11:25 PM
  2. MC9 Surface contour problems
    By kojack in forum Mastercam
    Last Post: 07-16-2008, 03:11 AM
  3. Surface Toolpaths
    By Flying Scot in forum Mastercam
    Last Post: 02-06-2008, 01:06 AM
  4. Surface contour toolpath (odd)
    By jnc in forum Mastercam
    Last Post: 04-23-2007, 01:16 AM
  5. Surface toolpaths Help
    By Julian M in forum Mastercam
    Last Post: 10-06-2006, 09:31 PM
