This is the best photo I have at this stage.
There are actually 4 bearing rails on the Z axis.
The inner two are opposed bevel type, the outer two are cheap supported rail type.
Currently the front supported rail type only has one bearing unit on it. (there are two well spaced ones on the rear)
I will add a second bearing unit to the front rail and add some gussets.
The bearing set-up isn't ideal, but I ran out of room due to some oversights in design.
As you have pointed out, the supported rail blocks will spread with lateral load.
Attachment 204034
