I've been testing my machine, and discovered that when I turn the spindle up to just over half way, the Z axis stepper starts twitching. I'm using a mini-mill spindle assembly with speed controller and a simple TIP120 Unipolar driver for the steppers (until I build a PICStep).
Any ideas why the RF noise is affecting the drivers? It only happens when the interface is powered up (computer can be on or off), and the spindle speed is above half.
This weekend, I went through all the trouble of replacing the spindle power wire with a sheilded one, and ensuring all the stepper wiring is shielded and grounded as well. The drivers are inside a SCSI box, so they should be well sheilded. I tried wrapping various things in tinfoil to try and isolate the source; to no avail.
I'm going to try swapping out the Z driver next in case it's particularly sensitive to RF noise.
Does anyone have these kinds of issues with their PICStep drivers? Maybe my solution is to hurry up and get new drivers made.
BTW. If anyone is using a mini-mill spindle for your machine (ie from Little Machine Shop), be sure to open up the electronics box and connect the ground wires together. They usually are bolted together when mounted to the mini-mill, but in this case they are just floating around the box.
