I am looking for the pretty much largest mill I can find for ~1000 or so. If it is a really sweet deal I might save a little longer and buy that. So far I have been looking at the X3 and RF45 clones (X3 is in my budget, and I am trying to decide how worth-the-wait the RF45 would be over the X3). I am looking for something that I could use manually for a while (namely to make the parts for a CNC conversion, and also maybe additional things like mill accessories and what not). I have a full Xylotex 4-axis CNC kit with 425oz-in motors, but I am not in too much of a hurry to make use of it. I am tired of making hasty mistakes so Id rather take my time setting that much.
Does anyone have any pics or experiences with the RF40? I basically "discovered" it today during lots of reading around this board, and I believe it is the same one sold at HF (http://www.harborfreight.com/cpi/cta...emnumber=42827), and seems (by apperance and specification) to share the same table and maybe base with the RF45. I ask because, due to entire head assembly being mounted in front of the column, and the swivel providing a flat rear surface to mount to, it might be relatively simple to convert it to a square-column setup (whether by modifying the stock column via maybe a milled square tube slipped and secured over the round part, or creating an entirely new one). This means the RF40 could be purchased for around 1060 from HF (at the current 999 price), and then about 200-300 put into it, and I could end up with a better Z-axis assembly than the RF45, for still, at minimum, about 200 less than even the Lathemasters RF45 (which would still be about 1450-1500 after shipping).
And, here is a specific question:
Should I expect the RF40 from HF to have the same table and travel as the one from Grizzly ([http://www.grizzly.com/products/Gear...-Drill/G1126)?
Isnt it true that all the carriers of the Chinese / RF (Thai?) mills now carry the same versions of each model? Like, the X3 from HF is listed differently than the X3 from Grizzly, but one person on here bought it and said that they are the same, just that the HF specs are wrong. I also notice that the table and base from the RF31 from Grizzly (http://www.grizzly.com/products/2-HP-Mill-Drill/G1006) might be the same, with the same listed 24" X-travel (though shorter Y-travel, for whatever reason). This makes me wonder if the same table, and maybe even the base, is shared between their larger mills, which leads me to believe that all their new models would share the same table / base (and thus travels), indicating that HF is simply wrong again about the listed travels.
Err... let me shorten that a bit. Can anyone verify the RF40's table size / travel based on experience? Or maybe confirm that all RF40 versions are the same unless specifically mentioned (like the IH RF45, since it was known to be bigger and better than the other 45 clones, and I believe advertised that way)?
Sorry if I was rambling!
*edit*
Edited a few things.
BTW, uses for the mill in the long run will be primarily small-scale production of automotive flanges (in mostly mild steel, with occasional aluminum and SS work) in thicknesses from .125" to .375", as well as other things like billet alumnum RC car parts, and other things. I would also like the capability of things like surfacing cylinder heads (something Id think the X3 could be made to do) and small engine blocks (something that would require a bit more than the X3 I think could handle). I know a vertical mill would be best for those engine operations but dont have the budget, and probably not the space for a bridgeport or something like that.
I have other things Id want to do also, but they arent really any more challenging than what Ive already mentioned.
Thanks!
