603,316 active members*
2,520 visitors online*
Results 1 to 5 of 5
Threaded View
    Jan 2012
    RFQ for 4 Prototype Aluminum Blocks
    I would like quote for 2 of 116-789350 and one each of the ludl_support* parts. All are 6061 aluminum blocks. Drawings are attached - 3D files available if it helps. Preference towards local Pittsburgh, PA shops, but anyone can offer quotes. If we like the work (including price and delivery time), we could use you again for small jobs and prototype work. Thanks!
    Drawing Corrections:
    the m6 tapped holes in the ludl_support* drawings should be 6.6mm UNTAPPED thru holes. the counterbores are 11.2mm diam and 6.0mm deep
    Attached Files Attached Files
  1. Prototype Aluminum Enclosure
    By pilotptk in forum RFQ (Request for Quote)
    Last Post: 09-22-2011, 03:52 PM
  2. Help with purchase recommendations: small CNC mill for prototype aluminum?
    By jkujawa in forum Uncategorised MetalWorking Machines
    Last Post: 05-21-2011, 11:46 PM
  3. Three prototype ram blocks required
    By Mudgey in forum Employment Opportunity
    Last Post: 07-28-2010, 08:34 PM
  4. RFQ Simple Aluminum Bearing Blocks
    By b0gh0s in forum Employment Opportunity
    Last Post: 12-23-2004, 10:57 PM
