587,143 active members*
5,491 visitors online*
    Nov 2003
    43
    RFQ Aluminum bending into c channel
    I am looking for quote for bending aluminum.
    .090 Alum
    14.5 W
    11 H
    Will be machined and bend lines will be drawn. need 4 bends to make a C channel.
    Close to the midwest, WI preferably
    Bruce
    Bruce
    Aug 2003
    73
    If you only need one of these it would probably be best to get someone local. Check with local welding/fabrication shops there should be one that would do this for very little money.
    Jeff T.
    http://www.3dcarvestudio.com
  1. Bending Aluminum Pipe in small radius
    By gcamlibel in forum Bending, Forging, Extrusion...
    Last Post: 07-07-2011, 08:23 AM
  2. Store front aluminum channel ?
    By Bzooka in forum Open Source CNC Machine Designs
    Last Post: 05-04-2010, 09:40 PM
  3. Bending 1/4" aluminum plate
    By SRT Mike in forum Bending, Forging, Extrusion...
    Last Post: 12-04-2006, 03:21 PM
  4. Bending Aluminum Bar
    By energyforce in forum Bending, Forging, Extrusion...
    Last Post: 04-12-2006, 05:09 AM
  5. Bending small aluminum rod
    By Twmaster in forum Bending, Forging, Extrusion...
    Last Post: 08-07-2004, 01:50 AM
