588,626 active members*
5,846 visitors online*
Results 1 to 9 of 9
    May 2007
    9
    RFQ - Aluminum Parts - small job
    I need a total of 6 pieces using 6061-T6. The flat pieces are 1/4" thick. The rings are 35mm thick. They will have 80mm OD bearings inserted so the bore must be a fairly high tolerance (not press fit but snug). I have never worked with DXF files before, so please let me know if there is additional data needed. You supply the stock.
    Thanks in advance.
    Lee
    Attached Files Attached Files
    Mar 2007
    67
    Data
    Hello, please add some dimensions to your Drawings and if you have some sort of cad file, e-mail it to us using ouur e-mail address off of our profile here, we use Mastercam8 and BobCAD-CAM21
    AMW
    May 2007
    9
    The parts were designed using eMachineShop. I can only export the DXF format I posted. What dimensions do you need? Hole sizes, distance between holes, etc?
    I have attached files with the dimensions drawn in. The distance between the four center mounting holes is not extremely critical; just as long as the holes in all the pieces line up.
    Apr 2006
    50
    I'm guessing the quote from emachineshop was high. You could try http://www.bigbluesaw.com, they're cheaper for plate work.
    Also the rings do they really need to be 35mm thick or could you have two thinner rings with spacers or multiple rings stacked?
    May 2007
    9
    Quote Originally Posted by ajmoir View Post
    Astronomically high. The thick ring could be a stack of eleven 1/8" rings.
    Jul 2005
    80
    Hmm. Dont know what is going on but when I import these DXF files all the entities are splines. Even the circles. Any input?? Mike.
    Apr 2006
    50
    I would split it up the rings and then submit it to bbs, let us know if it makes a difference, for instance I just had 3 plates done .25" in 6060, 2 6"x3" and 1 2"x7" all with various holes and rounded corners, came out about 25 bucks per plate.
    Multiple parts of thinner material should be cheaper.
    Mar 2007
    67
    RFQ Status!
    Is this RFQ still open?
    >>>I submitted a quote to you!<<<
    Would like to know the status of your RFQ
    thanks
    AMW
    May 2007
    9
    Results posted in Feedback area.
  1. small parts
    By inpro in forum Machine Created Art
    Last Post: 01-26-2007, 12:52 PM
  2. How hard is it to get into CNC Machining small aluminum parts?
    By GreasyMidget in forum MetalWork Discussion
    Last Post: 10-13-2006, 03:20 AM
  3. RFQ small parts
    By impact in forum Employment Opportunity
    Last Post: 12-30-2004, 12:06 AM
  4. contouring aluminum with small bit
    By corpse in forum Benchtop Machines
    Last Post: 09-14-2004, 07:11 PM
  5. Bending small aluminum rod
    By Twmaster in forum Bending, Forging, Extrusion...
    Last Post: 08-07-2004, 01:50 AM
