603,790 active members*
2,972 visitors online*
Results 1 to 4 of 4
    Dec 2006
    21
    RFQ: Barrel Clamps
    I am building a rail gun (see links below for more complicated examples than I'm building) and need someone to build three barrel clamps for me.
    I have all the measurements except the size of the hole that the barrel goes through. I don't know how large it should be securely clamp the barrel. The rifle is a Ruger 10/22 (.22lr) with a heavy 16.5" bull (.920 muzzle to breech) barrel so recoil is very minimal.
    Thank you very much!
    Here are the drawings I made up (I am not a machinist):
    http://thenerdfarm.com/zenpw/Barrel-Clamp.gif
    Here are some way more complicated examples of similar guns:
    http://benchrest.com/showthread.php?...ail-Gun-Photos
    http://thenerdfarm.com/zenpw/Rail.jpg
    http://thenerdfarm.com/zenpw/Rail-gun2.jpg
    http://thenerdfarm.com/zenpw/Mike2004rail-1.jpg
    There is a discussion about this project located here: http://www.cnczone.com/forums/genera...hole_do_i.html
    Dec 2008
    69
    I could machine and hone these clamps in addition to grinding the barrel. If you'd like to incorporate bushings we have the facilities for that as well. What kind of price range and time frame are you looking for? Do you need help with the design work? [email protected]
    Sep 2011
    The vertical dimension is not on your drawing, do you have a dimension for that?
    Butch
    Dec 2006
    21
    Thanks for all the messages and feed back from everyone.
    Forgot about height. Updated the drawing: http://thenerdfarm.com/zenpw/Barrel-Clamp.gif
    I was thinking aluminum would be acceptable.
    I think bushings would be kind of overkill.
  1. Need parts: Gooseneck & Clip on clamps/screw bar clamps, padded
    By LordStDennis in forum RFQ (Request for Quote)
    Last Post: 06-28-2011, 12:07 AM
  2. small barrel
    By cheddar11 in forum RFQ (Request for Quote)
    Last Post: 05-19-2011, 03:08 PM
  3. Barrel Lens Mounts
    By joekenney in forum Employment Opportunity
    Last Post: 12-30-2010, 05:25 AM
  4. How to add rifling to a barrel?
    By Adam Baker in forum Uncategorised MetalWorking Machines
    Last Post: 02-23-2010, 06:28 PM
  5. DIY Barrel vibratory... HUGE
    By Cronicstorm in forum Mass finishing equipment/media/strategies
    Last Post: 09-20-2008, 01:16 AM
