587,086 active members*
2,878 visitors online*
Results 1 to 5 of 5
    Nov 2006
    20
    Post RFQ: CNC turning in mild steel
    Hi folks. I need some simple pieces cut for a reasonable price in mild steel. Willing to work with your schedule.
    Test run is 8x wheel, 4x axle. Production run will be 48x wheel, 24x axle. If all goes well, there will be repeat production orders.
    Thanks!
    Chris Cardinal
    cscardinal AT live.com
    Nov 2006
    20
    Files now downloadable from the forum for those that asked.
    C.
    Attached Files Attached Files
    Nov 2006
    20
    Exclamation revised files
    There seems to be some trouble with the first set of files.
    Here is a revised set of files.
    Thank you!
    Dec 2012
    19
    I can give you a good rate on these. Email me at [email protected] with an estimated lead time and a shipping address, and I will reply with an accurate quote. Also let me know how tight the tolerances need to be. Thanks!
    Nov 2006
    20
    Email sent. I can fit your work schedule as I am flexible.
    Thanks!
  1. cut mild steel?
    By dharps in forum DIY CNC Router Table Machines
    Last Post: 04-01-2011, 03:33 AM
  2. RFQ - Quote for cnc turning job, EN8 mild steel lot of 500
    By Sheepspeed in forum Employment Opportunity
    Last Post: 11-02-2010, 04:07 PM
  3. speed for turning mild steel
    By noshoesnoshirt in forum MetalWork Discussion
    Last Post: 08-16-2009, 03:31 PM
  4. Mild Steel
    By MBG in forum MetalWork Discussion
    Last Post: 03-09-2007, 11:20 PM
  5. Machining Mild Steel
    By georgebarr in forum Uncategorised MetalWorking Machines
    Last Post: 06-30-2005, 12:54 AM
