Hi
We want to build a prototype for a peristaltic pump that would be used for pumping bakery icing. The persitaltic pump is a pretty simple design, flexible tubes containing icing are squeezed between the platten and the rotating rollers.
This is just a prototype, so if you see anything that would simplify or use "off the shelf" parts I'd be open to it. Assume that the fractional dimension tolerances are +- 1/32". Otherwise machined tolerances are given.
Thank you
Doug Antonides
