587,299 active members*
3,475 visitors online*
Results 1 to 4 of 4
    Oct 2016
    23
    RFQ: Hole needed - LOL
    I need a chunk of steel shaft with a hole down the middle. It's a tool. It's designed to put a slight taper on a piece of metal conduit pipe when it's hammered inside. The outside of the tool does not really need to be milled if it is larger than specs. CAD files are attached below. The tricky part will be getting the interior slope straight so the pipe tip does not curl inwards when it's hammered inside. It will be 0.4 lbs and it's height is 1.79". Also let me know if you have any shipping charges that are over and above the carrier's charge. Thanks.
    https://www.dropbox.com/s/4f9xsiba4g...20CAD.zip?dl=1
    Dec 2014
    78
    Quote Originally Posted by CutOnce View Post
    What material are you wanting it made out of?
    Oct 2016
    23
    Re: RFQ: Hole needed - LOL
    Many thanks to ChrisW for jumping on this and making it happen so fast! Here's the pic he sent:
    May 2003
    323
    Thank you.
    Chris
  1. moving hole made using hole wizard SW2011
    By themotorman in forum Solidworks
    Last Post: 11-16-2014, 05:51 PM
  2. Replies: 9
    Last Post: 09-18-2012, 12:11 AM
  3. Hydraulic hole punch recommendation needed
    By brouser1 in forum MetalWork Discussion
    Last Post: 06-18-2012, 02:42 AM
  4. Replies: 18
    Last Post: 03-21-2011, 11:28 PM
  5. Figuring turns needed on threaded hole
    By Josh_Putman in forum MetalWork Discussion
    Last Post: 06-10-2010, 12:10 PM
