I am looking to get some gear made for testing, and maybe later on to order in bulk. The gears I need have to be Mod1 gears, with a thick/strong hub and atleast a 4mm set screw. The width of the teeth should be 1cm wide, along with a .5cm wide hub, so top to bottom the gear will stand 1.5cm. The ammout of teeth are 15, 16, 17, 18.
Later on I will be looking at getting some mod1 60t spur gears made as well.
