QTY 1,
Shipping Zip code: 37347
Material: Aluminum
QTY 1,
Material: Aluminum
You're missing a few dimensions in your detail view and no tolerances are mentioned.
I see that now,
Thank you for pointing this out,
The depth of the Ø20.5 hole is: 3mm
The depth of the Ø18.50 hole is: 5mm
Please assume loose tolerance on this project to reduce cost, it's not a vital part to the project. The most critical dimensions on this part is the Ø20.5, Ø26.0 and Ø18.50 holes.
I am interested in quoting. All I do is low volume quantity part...this is right up my alley. What is the required date of delivery? PM me when you have time.
Note to add:
The 0.5 and 2.5 radius relief cuts are variable values, they are added just to avoid sharp corners, if you would like to use another value for these two radius, please just let me know.
Thanks,
Joe
This job request has be rewarded,
Thank you all who quoted,
Joe
