603,385 active members*
3,235 visitors online*
Results 1 to 4 of 4
    Sep 2012
    RFQ for simple part -- drawer pull
    I'm interested in machining and finishing of some drawer pulls like attached photo. Material is stainless with satin finish. Quantity is 30. No dimension is critical. Although I only called out major dimensions in attached, note that part will include the countersunk hole for screw, and fine radius or chamfer on all edges like in the sample. I can provide DXF, but initially just looking for estimate. Time frame is 6 weeks.
    Sep 2006
    6
    I do these all the time. You cannot find this part cataloged?
    I will quote it for you.
    You want the bead blasted finish as well, or do you just want it machined and you will handle the finish work?
    Brian
    Sep 2006
    6
    A dxf? You have all the dimensions already. If someone needs a dxf for that part, Id be scared to award them the job.
    Throw some screw data in there and you are golden.
    304?
    Brian
    Sep 2012
    304 fine. Bead-blasted. I have not found anything like this in catalogs. This particular one is custom-manufactured by a cabinet maker who does not sell components.
    PM me quote. Thanks!
  1. Matsuura bt35 pull stud, part number?
    By Brian FRF in forum Uncategorised MetalWorking Machines
    Last Post: 03-28-2013, 05:26 AM
  2. Simple two operation part
    By honk in forum EdgeCam
    Last Post: 12-02-2009, 09:58 PM
  3. HELP ANY ONE HAVE A PART SOMETHING SIMPLE
    By bobrob in forum MetalWork Discussion
    Last Post: 03-26-2009, 05:22 PM
  4. Please Help!! Simple 3-D part not so simple for me
    By eaglegage in forum Mastercam
    Last Post: 05-15-2008, 04:00 PM
  5. RFQ on simple part...
    By nate in forum Employment Opportunity
    Last Post: 04-28-2006, 07:25 AM
