I need 6 pcs of this part from 6061 or 7075. The bore must be concentric and held tightly for a 13mm bearings
I have seen your print. What kind of tol. do you have. Everything is .xxxx in the print.
Sorry about that, I drew it up in Surfcam. Tolerances are +-.005 on everything except concentricity of the bore. I'd like that within +-.001 to itself in the front and back.
Russ
