587,887 active members*
3,353 visitors online*
Results 1 to 4 of 4
    Feb 2009
    25
    RFQ - Turned Delrin/Nylon/Aluminum
    Looking to have 4 different designs of bushings & cups turned. I would like an RFQ of these Designs & Quantities in each of these materials; Nylon, Acetal Delrin & 6061-Aluminum
    Design # 001: Qty 12
    Design # 002: Qty 14
    Design # 003: Qty 2
    Design # 004: Qty 2
    Units: Inches
    Tolerance: +/- 0.010
    Material(s): Nylon, Black Acetal (Delrin), 6061-T6 Aluminum
    Add'tl Notes: The outer diameter can be raw stock, no machining required. Design # 002 & 004 are a cup design.
    Please PM me all Quotes, or if you have further questions. Thanks!
    Attached Files Attached Files
    Jan 2009
    23
    Smile hi,
    sent pm,
    www.hewittsmachine.com
    thanks
    Jan 2008
    449
    AuroraDrvr,
    Read the pm I sent you, please.
    Feb 2009
    25
    RFQ has been filled. Thank you for the bids.
  1. Is Delrin better than Nylon?
    By CNCWNTTOBE in forum Glass, Plastic and Stone
    Last Post: 12-07-2008, 07:38 PM
  2. Turned aluminum piece
    By raidfibre in forum Employment Opportunity
    Last Post: 02-19-2008, 02:39 PM
  3. Turned/Milled Delrin.
    By LateNight72 in forum Employment Opportunity
    Last Post: 01-22-2008, 12:33 AM
  4. .5 Mod Delrin or Aluminum Spur Gears
    By Crazy Phantom in forum Employment Opportunity
    Last Post: 01-10-2006, 12:40 AM
  5. Uhmw Or Delrin Or Nylon For Antibacklash Nut?
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 11-19-2003, 10:39 PM
