587,997 active members*
2,151 visitors online*
    Aug 2007
    14
    RFQ: turned externals on aluminium tube
    Material: 1.5" OD (38.1mm) x ~32mm ID aluminum tube (6061?). ie. 1.5" diameter with 3mm wall thickness.
    Simple turning of the OD, nothing needed internally. Basically a 120mm long tube with the first 80mm turned down to 36mm OD, the rest skimmed off for a smooth finish, and some cosmetic grooves added (dimensions don't need to be accurate, just consistent).
    Would like a nice clean finish on these, and preferably the sharp edges taken off a bit; not sure how to represent this on the drawing (I'm not a CAD person).
    The design could be expanded to include some milling and drilling, depending on quotes.
    Quantity: 5/10/50/100
    I'm expecting to require about 20 of these a month if production goes ahead. There are several other required pieces to be quoted on in the future.
    Location: I'm in Brisbane, Queensland, Australia, so would prefer an Aus based machinist, but depends on costing and time; I'm quite happy to receive bulk lots from overseas if the price is right and they can be delivered in a timely manner (I'll be working with a JIT production strategy, but can stockpile common parts like this one)
    You can contact me via email: lee at baudalign dot com
    and I'll be checking in here every now and then.
    Design:
    http://baudalign.com/lee/pics/rearCommon_new.pdf
    Lee
    Aug 2007
    14
    Quote Originally Posted by RoGuE_StreaK View Post
    Sorry, that should be 75mm (as per diagram), not 80mm
    Aug 2007
    14
    Just a quick note of thanks to those that have provided quotes, I'm now in talks with a machine shop in Western Australia (not sure of his username here).
  1. RFQ 4 turned bushings
    By SPEEDRE in forum Employment Opportunity
    Last Post: 01-16-2008, 10:53 PM
  2. A turned part
    By DennisCNC in forum Community Club House
    Last Post: 09-09-2007, 10:56 PM
  3. RFQ - turned parts
    By Runner4404spd in forum Employment Opportunity
    Last Post: 11-01-2006, 04:57 AM
  4. Help with turned spline
    By Dgriff in forum Mastercam
    Last Post: 01-30-2006, 05:51 AM
  5. Cutting aluminium tube
    By cnczoner in forum MetalWork Discussion
    Last Post: 07-09-2004, 11:06 PM
