603,310 active members*
2,441 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > Rhinocam 2018 : 4th Axis Drive Surface Machining, Gcode Error
    Jun 2021
    Hello, I tried to generate Gcode with 4 axis "4th Axis Drive Surface Machining" for a simple milling.
    The Gcode calculate x,y,z,angle parameters.
    I would expect that these coordinates x,y,z correspond to the position of the CNC head but in fact the gcode x,y,z correspond to the tool end coordinates
    If I change the tool length, it is taken into account in the RhinoCam simulation but no effet in the gcode generation
    I also tried to change the parameter "gage length (for machines with a rotary head)" but without any impact on Gcode generation.
    Would you have an idea to solve this issue ?
    Apr 2004
    5948
    Re: Rhinocam 2018 : 4th Axis Drive Surface Machining, Gcode Error
    Have you asked MecSoft tech support for help with this? They're usually pretty good at figuring out specific use-case problems like this.
    Andrew Werby
    Website
    Jun 2021
    Thank you for your advise. Could you send me the link to contact this MecSoft tech support ? Thank you
    Apr 2004
    5948
    Try this: https://mecsoft.com/request-support/
    You can also call the phone number on that page.
    Andrew Werby
    Website
