603,935 active members*
3,721 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller Cards > RichAuto A12 CNC Controller Board connection.
    Gidday from down under,
    we are currently replacing the original 0501 pendant cnc controller on our Baileigh PT-44VH cnc plasma with the new RichAuto A12 controller and board. The problem we are having is knowing which terminal to connect the 3 wires that control the Thermal Dynamics A120 plasma cutter. The wiring diagram for the old card is nearly un readable and there is no indication on the new card as to which terminals these go to. I have attached pics of old card and new card and any help would be greatly appreciated.
    cheers Marty
    Mar 2017
    Re: RichAuto A12 CNC Controller Board connection.
    Did you ever figure this out? I have a Baileigh PT-22 that came with the A12 controller. I want to add a Z-Axis and THC to the machine. As far as I could figure out, even with a stand alone THC controller that uses it's own driver for the Z-Axis, there was no input available on the controller for ARC_OK to delay the motion.
    If you did figure it out, did you have to modify your own post processor to get the CAM software working?
  1. Confused about CNC Controller (Richauto-autonow-A11e
    By matt_man in forum Controller & Computer Solutions
    Last Post: 01-14-2021, 10:16 PM
  2. Richauto A11 DSP controller problem
    By atled in forum Controller Cards
    Last Post: 04-08-2019, 03:36 PM
  3. PUMA SM Thyristor controller to Breakout board connection
    By Farmer9009 in forum Spindles / VFD
    Last Post: 11-04-2017, 05:06 AM
  4. RichAuto controller issue
    By bonerbill in forum USA Club House
    Last Post: 09-30-2016, 07:43 AM
  5. helps in cnc board connection
    By rcerqueira in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-09-2015, 02:03 AM
