588,182 active members*
4,212 visitors online*
    Feb 2005
    101
    Rigid ram head rotation?
    Hello. Once again I have to move my R2E4. Unfortunately it has to pass under some low beams which the head will not clear. Last time I just removed the head which was a serious pain given the lack of ceiling clearance. Basically I ended up just manhandling it on there.
    So my question is... will the head bolt on at a 90degree angle from upright? It is a rigid ram. Ie if I unbolt it and rotate 90 will it bolt down that way? It looks like the bolt pattern is near square but it is hard to eyeball. If I could do this it would save me a lot of trouble.
    If anyone knows it would be greatly appreciated! Thanks in advance!
    James
    Oct 2009
    Got mine all apart. looks like you can't do it. Bolts aren't square pattern and the gear that adjusts squareness isn't center of the bolts anyway. If you could do it, you would have to watch out for the oil line that goes to the ball screw. it goes through the head and we had to cut our to take the head off.
  1. Tapping head or rigid tapping
    By Gregory_C in forum Syil Products
    Last Post: 10-18-2008, 06:49 AM
  2. tool head rotation about z-axis
    By eurosoftjohn in forum G-Code Programing
    Last Post: 10-14-2008, 06:46 PM
  3. Tramming the rigid ram head - how? Need to R&R...
    By swarf_rat in forum Bridgeport / Hardinge Mills
    Last Post: 06-10-2007, 12:23 PM
  4. Rigid tapping or tapping head
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 09-24-2006, 06:08 PM
  5. 5th Axis head rotation questions.
    By whiteriver in forum DIY CNC Router Table Machines
    Last Post: 11-19-2005, 08:07 PM
