Re: Rigid tapping thread form is not correct
hi, when tapping creates problems, is good to compare actual setup with another, using same tool, so not to blame the tool
thus is good to considere / assure that the tool is correct
we have a manual taping thing where i can test things ( check attached ), so if they work there, then also the cnc should deliver it
a tap longitudinal movement is not linear, but with small deviations, depending on it's precision class and on the material characteristics a fine pitch thread is also affect by this, and the impact of the cnc sync is much greater : thus the desincronization leads to much more wear on a fine pitch tap, comparing to a normal pitch tap : so use floaters
each cnc syncs rigid with a tolerance, and that tolerance is <> tool crafting tolerance, even if both machine and tool have same tolerance class, and this difference leads to stress on tap teeth is there a floater in the house ?
the tail of a tap may oscilate inside a cone, not only when the tap starts, but also among the way : 2 dial comparators on the tap shank may show this / the biting of a tap is not simetrical, like when drilling, but more like when drilling with a drill with 2 inserts, thus there is a tendency to tilt : this requires a floater with small angular or radial play
if there is no holder in the house, you may build one, similar to holding threading dies on a lathe, inside the tailstock : thus do something so to allow the tap to self feed a quick change tap collet chuck with overhang ? the overhang is there to allow radial play, and the collet chuck should allow self feeding, because it is not a very precisional part, but with some play within it, so you may achieve self-feed without a self-feed holder ... kind of
try also to tap at hand : does it cut ?
if a tap cuts, and if it is self feeding, then most problems are eliminated so does your tap cut, and is it self feeding ?
the threads work and everything seems to measure fine, but the threads are definitely crappy
... maybe i know how is to deliver messy threads that pass the go and no-go gauge & maybe sometimes is enough for me to find the cause, not also to fix it / kindly
