603,939 active members*
1,943 visitors online*
Results 1 to 4 of 4
    May 2007
    59
    Robotic Mig Available
    Our company has a Robotic MIG welding system available. The robot is used and in good shape, but the positioner / operator station are new.
    6 Axis Motoman Robotic Welding System
    Comes With:
    1- 6 axis robot and controller
    1- 350 amp welding power supply w/cables (400 amp also available)
    1- robotic welding torch w/cable
    1- MIG wire feeder
    1- New robot platform with 2 station rotary table
    1- New welding gas regulator/flow-meter +hose
    I am a designer for the company I want the floor space, for a pet project of mine. I believe the price of this used mixed with new system would be around $20k. I know that if I were quoting a new build, it would be between $110,000 to $120,000.
    We picked this system to do repetitive welding jobs in our own shop, but we usually build one off projects so we have no repetitive welding jobs.
    The machine has a two station table, so you can load/unload while the robot is welding the other side. Very efficient.
    Oct 2003
    352
    Do you have any pictures available?
    May 2007
    59
    I hope to have pictures by sometime next week.
    Due to our floor space issues, I cant get a good shot at it until some other pieces are moved.
    If you are truly interested, send me personal reply w/email address and I will try and get you some preliminary pictures.
    May 2005
    674
    Posting your exact location will probably help. And any pics are better than no pics... the sooner the better.
  1. Use a robotic arm instead of building cnc mill?
    By SCCoupe in forum DIY CNC Router Table Machines
    Last Post: 06-20-2007, 09:23 PM
  2. DC motor to robotic servo
    By max_imum2000 in forum Servo Motors / Drives
    Last Post: 08-19-2006, 12:56 AM
  3. Question for Robotic Arm guru's........
    By jaxnorth in forum RC Robotics and Autonomous Robots
    Last Post: 12-29-2005, 07:40 PM
  4. Take a Ride on a Robotic Arm...
    By JavaDog in forum Community Club House
    Last Post: 10-14-2005, 09:27 PM
  5. Intersting robotic joint
    By Zathras in forum Mechanical Calculations/Engineering Design
    Last Post: 10-07-2005, 07:05 PM
