588,648 active members*
4,990 visitors online*
Thread: rod diameter
    Oct 2008
    14
    rod diameter
    Im desiging a cnc router (75cm x 50cm in size) with a moving table and stationary gantry to cut wood. I've decided to use linear bearings on round metal rods. but. How can I work out what diameter rod to use (and material). given that the table will weigh a couple kilos. with a couple more kg pushing down on it from the router.
    Many thanks.
    Aug 2008
    1166
    To answer the basic question of what size rods to use, you can start with a basic beam deflection calculation:
    http://www.engineersedge.com/beam-deflection-menu.htm
    In particular, you might want:
    http://www.engineersedge.com/beam_be...m_bending2.htm
    This will be a conservative estimate as the ends of your rods would not really be simply supported. This will let you see how much your rods will deflect for a given load. Loads will include the weight of components and cutting forces. Your goal would be to pick a rod that gives a deflection that is small enough to meet your goals for the machine.
    You'll need to know the area moment of inertia to use the above formulas:
    http://www.engineeringtoolbox.com/ar...ia-d_1328.html
    You'll also need to know the modulus of elasticity of the material you want to use. This can also help you pick a material - different materials will have different values of E and will give different deflections. Try www.matweb.com for lots of material properties. Some conversions might be necessary to make all the units work out.
  1. why doesn't go to correct diameter
    By andrejculk in forum Fadal
    Last Post: 12-11-2008, 06:46 PM
  2. Diameter offset
    By qmas99 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-25-2008, 01:31 AM
  3. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum DIY CNC Router Table Machines
    Last Post: 12-24-2007, 09:51 PM
  4. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum Uncategorised MetalWorking Machines
    Last Post: 12-15-2007, 04:25 AM
  5. diameter off
    By mike9696 in forum Fanuc
    Last Post: 04-11-2007, 01:32 AM
