603,365 active members*
2,934 visitors online*
IndustryArena Forum > Community Club House > ROLL GRINDING MACHINE
    Mar 2009
    43
    Question ROLL GRINDING MACHINE
    Hi friends, what is the different between cylindrical grinding machine and a roll grinding machine regarding with its operation and components?
    Regards
    keyan
    Mar 2006
    2712
    Some roll grinders use abrasive belts and are mostly used to grind rubber rolls.
    For the steel and paper industries, roll grinders are very large and have travelling wheel heads rather than reciprocating tables.
    Smaller rolls and smaller printing cylinders are often ground on precision reciprocating table grinders. These machines are usually top end machines, not cheap imitations.
    Hope that helps,
    Dick Z
    DZASTR
  1. Ejector pin grinding/cut off machine?
    By Chuck Reamer in forum Moldmaking
    Last Post: 12-20-2013, 01:44 PM
  2. Simple question: Hot roll vs cold roll steel
    By CuttersCov in forum MetalWork Discussion
    Last Post: 01-10-2013, 02:42 PM
  3. Building a slip roll machine
    By Woodie1 in forum Bending, Forging, Extrusion...
    Last Post: 10-09-2010, 07:11 PM
  4. hacking a roll to roll tape printer
    By ybakos in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 12-17-2009, 11:22 PM
  5. On A Roll - Another new machine
    By vacpress in forum DIY CNC Router Table Machines
    Last Post: 10-31-2007, 04:17 PM
