588,655 active members*
5,863 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Roll threading 2-56 look issue
Results 1 to 4 of 4
    Feb 2008
    8
    Angry Roll threading 2-56 look issue
    We are thread rolling an alum extrusion 2-56 (kinda gummy characteristics) 6063 maybe not real sure.
    Question 1: Does any one have any info on how the threads are supposed to look?
    The recomended size is .078-.080. we went with .0765 roughly. the threads still look like they have 2 crests, top and bottom.
    Question 2: Is this typical for thread roller taps?
    Any info on this matter would be greatly appreciated. nfs
    Jan 2007
    1389
    The threads will look like threads with out burrs.
    I get a reccomended drill size of 5/64 or .0781, your .0015 smaller and in all honestly that may make a difference in a 2-56. but I doubt it.
    Its not typical as what you describe.
    does the hole your drilling have a nice finish? if the finish looks bad in the drilled hole then so will the thread on the minor.
    are you sure you have the proper lead programmed in (feed rate) if your off on a small thread like this it will make a huge difference.
    Delw
    sticky material on small threads make sure you use good strong coolant
    Feb 2005
    376
    The 2 crests would indicate an oversize hole and the thread isn't completely forming.
    Double check your hole size, the actual size of the hole made, not the drill.
    Feb 2008
    8
    Thanks for the help, this mat'l is real gummy, we went with a .075 drill and the threads look better now. thanks for the help. we also slowed the feed down on the drill from 10. ipm to 5 ipm seemed to help stabilize the hole size.(side note: tried .074 drill in 6061 then tap and tap broke immediately
  1. Simple question: Hot roll vs cold roll steel
    By CuttersCov in forum MetalWork Discussion
    Last Post: 01-10-2013, 02:42 PM
  2. roll form tap better in 316 stainless?
    By stovepipesteve in forum Haas Mills
    Last Post: 08-05-2008, 12:26 PM
  3. Roll tapping.
    By Mitsui Seiki in forum G-Code Programing
    Last Post: 06-17-2008, 05:37 AM
  4. On A Roll - Another new machine
    By vacpress in forum DIY CNC Router Table Machines
    Last Post: 10-31-2007, 04:17 PM
  5. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
