603,337 active members*
3,725 visitors online*
Thread: Romi g20
    Mar 2008
    14
    Romi g20
    The machine will not communicate. It doesn't recognize when a pcmia card is put in the port. It says "insert card"
    I have checked and rechecked all the parameters under the (rs232) section. Is there another parameter that needs to be set to activate the card reader?
    In the past someone had placed a start stop parameter in the handy page. This caused the owner to think Romi had disabled his card reader. So a "genius" took it upon himself to "fix" the problem. I don't know what he changed but I need that reader so I can install the spindle drive parameters.
    Jun 2014
    10
    Re: Romi g20
    Hi, sorry I seen so late the post. The only parameter that enables the use of the card is the parameter 20 must be in 4. anyway, this machine usually brings in the logbook the parameters of the spindle, because it has servo motor and driver instead of variable speed drive is easier to copy them one by one.
    regards
  1. ROMI G15SM
    By emexcee380 in forum Bridgeport / Romi Lathes
    Last Post: 09-23-2013, 12:54 PM
  2. Romi GL240
    By dukegunner in forum Bridgeport / Romi Lathes
    Last Post: 09-23-2012, 04:12 PM
  3. Romi M17
    By bigsuperbig in forum Bridgeport / Romi Lathes
    Last Post: 06-23-2011, 10:46 PM
  4. Romi M27 Help!
    By Shadetree in forum Bridgeport / Romi Lathes
    Last Post: 04-18-2010, 07:24 PM
  5. ROMI G20 CNC LATHE
    By LIGAMEC CORP. in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-11-2008, 11:34 PM
