588,587 active members*
14,384 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Rookie lathe question
Page 1 of 2 12
Results 1 to 20 of 22
    Sep 2010
    145
    Hello guys, I have V23 W/lathe and have a dumb question. Not being a lathe guy Im wondering. If you buy a lathe like a "swiss" were there isnt a turret and tool numbers but rather a tool plate. How do you call the tools / positions for each operation. Does BC allow for this or does it require hand codeing / fixing after the basic G code is made by BC?
    Question #2. Any significant changes to lathe V 25? Ive heard both ways, no changes and minor changes, anyone have it and care to comment?
    Mar 2012
    1570
    tubeguy,
    I think you are talking about gang tooling. I don't believe their would be any different programming other than a tool call, but I could be wrong. If there was like a special index move that didn't use a macro on the control then they could be scripted in.
    The lathe software from V24 to V25 is the same. They did not make any improvements to the lathe tool path features. From V24 to V25 the changes that were made that effect the lathe are the drawing tools.
    Stretch and preview changes the way you use the software for CAD, other than that no changes to the CAM for lathe.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Dec 2011
    361
    We do not support swiss machining at this time.
    Mar 2012
    1570
    Sean,
    I don't think he was asking if we support swiss, just the gang tooling.
    But to make things clear, BobCAD CAM Lathe software is just 2 Axis at this time.
    Al DePoalo
    Sep 2010
    145
    Maybe Im not even asking the question right. Yes Im talking about gang tooling as it would be on a kia lathe. The sort thats mounted on the cross slide. It would seem you could define each tool positon somehow and call it, right? But I also can see were there would be interference issues getting the tool away from the work. Again Im a rook on this and havent bought the machine for this reason. I need to understand what "it" needs better. If anyone has some insight on this please let us know what you think.
    Thanks....
    Dec 2011
    361
    It does not support gang tooling also. This is not an item that can be scripted
    Mar 2010
    1852
    Not sure about this particular gang lathe, but most call out tool numbers just like a turret lathe.
    I had one for many years and just touched off tool like a turret or a mill. Tool change position was just retracted all of the way in Z axis. Really very simple until you start setting it up for max speed and only retract just enough for each tool to clear. Most don't have much Z anyway.
    Can't you do some tool change just calling tools and offsets? It has been years since I had the lathe but I am looking at one right now. Hate to think I could not use BobCAD, but what the hell,used to write just by hand anyway.
    Mike
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Mar 2012
    1570
    I would think you could script the post "IF" something special was needed for the tool change. The best way to find out is to request a script and see what they say.
    http://www.bobcad.com/wp-content/med...ng-request.pdf
    Al DePoalo
    Sep 2010
    145
    I dont think I should have used the term "swiss" I guess theres more to that term then just a gang tool or tool plate type machine. My mistake. Were talking about a mostly typical machine but with a single moving plate that the tools are attached to. And a VFD driven head.
    BTW were there any fixes from V23 to V24 in lathe for a few of the tool radius, comp and library issues?
    Sep 2007
    356
    Sooo if BobCad doesn't do gang tooling that kind of sucks. When I bought my V25 I was told it didn't support live tooling, but I think I was told gang tooling was supported. I know I had mentioned that I was looking at an OmniTurn. I'm pretty sure that I was told that there was a PP available for it. I could be wrong... but I know I had asked about the lathe module. If BobCad doesn't support gang tooling what software are other guys using?
    Apr 2008
    1577
    Quote Originally Posted by ranchak View Post
    I would have to see a properly working program for a lathe with a gang tool setup but I see no reason this can't be done in BobCAD. I don't even see scripting as entirely necessary (depends on how much manual coding you want do). The controller should be doing all the work, BobCAD just needs to call the tool right and the user would need to be careful with the retracts between tool changes.
    Might you have to lie a little bit? Of course.
    Mar 2012
    1570
    I spoke with Brad at Dynamic Machinery Resources and he is going to send me a sample posted program that runs the fagor 8055 on a gang tooling lathe.
    This way we can see the code format, from there we will all know if BobCAD CAM can post the correct code or not. If there is something special needed in the code we will know what needs to be done with the post to make it work correctly.
    [ame=http://www.youtube.com/watch?v=rj5UI2epDKI&feature=channel&list=UL]Dynamic Machine Resources GT27 CNC Lathe Turning.mov - YouTube[/ame]
    Al DePoalo
    Sep 2010
    145
    OK, thanks for looking into it, this is a great forum.....
    Mar 2012
    1570
    Gang Tooling
    I did get a manual for the 8025TG Dynamic. At this time I am reviewing the information.
    Here is a sample drawing:
    free image hosting
    Here is a sample program for the drawing:
    Code:
    %00110
    N000 G90 G95 S3000 T1.1 M4 M8(TURNING TOOL)
    N010 G00 X.77
    N020 G00 Z0
    N030 G01 X-.01 F.003
    N040 G00 X.52 Z.01
    N050 G01 Z-.634 F.006
    N060 G00 X.55 Z.010
    N070 G00 X.41
    N080 G01 Z-.092
    N090 G00 X.43 Z.01
    N100 G00 X0
    N110 G01 Z0 F.003
    N120 G01 X.18
    N130 G03 X.3 Z-.06 R.06
    N140 G01 Z-.095
    N150 G01 X.39
    N160 G01 Z-.14
    N170 G01 X.5 Z-.3119
    N180 G01 Z-.636
    N190 G01 X.75
    N200 G00 Z1.
    N210 M01
    N220 G90 G95 S1200 T2.2 M3 M8(.125 DRILL)
    N230 G00 X0
    N240 G00 Z.05
    N250 G01 Z-.125 F.003
    N260 G00 Z.1
    N270 G00 Z-.115
    N280 G01 Z-.250
    N290 G00 Z.1
    N300 G00 Z-.240
    N310 G01 Z-.375
    N320 G00 Z.1
    N330 G00 Z1.
    N340 M01
    N350 G90 G95 S1000 T3.3 M3 M8(.05 WIDE GROOVE TOOL)
    N360 G00 X.625
    N370 G00 Z-.533
    N380 G00 X.515
    N390 G01 X.400 F.0015
    N400 G00 X.515
    N410 G00 X.75 Z1.0 M05 M09
    N420 M30
    Here is the coded commented out:
    Code:
    %00110
    N000 G90 G95 S3000 T1.1 M4 Absolute IPR spindle 3000rpm Tool 1 direction counterclockwise
    N010 G00 X.77 Rapid feed to X+.77 diameter
    N020 G00 Z0 Rapid to face Z0
    N030 G01 X-.01 F.003 Facing cut to X-.01 at .003 IPR
    N040 G00 X.52 Z.01 Rapid to X+.52 Z+ .01
    N050 G01 Z-.634 F.006 Feed to Z-.634 AT .006 IPR
    N060 G00 X.55 Z.01 Rapid to X+.55 Z+.01
    N070 G00 X.41 Rapid to X+.41
    N080 G01 Z-.092 Feed to Z-.092
    N090 G00 Z.01 Rapid to Z+.01
    N100 G00 X0 Rapid to X0
    N110 G01 Z0 F.003 Feed to Z0 AT .003 IPR, beginning of finish pass
    N120 G01 X.180 Feed to X.18, start of radius
    N130 G03 X.3 Z-.06 R.06 Generate a .06 radius
    N140 G01 Z-.095 Feed to Z- .095
    N150 G01 X.39 Feed to X+.39
    N160 G01 Z-.14 Feed to Z-.14
    N170 G01 X.500 Z- .3119 Feed along 10O taper
    N180 G01 Z-.636 Feed to Z-.636
    N190 G01 X.75 Feed off material to X+.75
    N200 G00 Z1. Rapid to Z1., Safe position for next tool
    N210 M01 Optional stop
    N220 G90 G95 S1200 T2.2 M3 Start-up block for tool #2 .125 Drill 1200 rpm clockwise
    N230 G0 X0 Rapid to X0
    N240 Z.1 Rapid to Z.1
    N250 G01 Z-.125 F.003 Feed to Z-.125 at .003 IPR
    N260 G00 Z.1 Rapid out to Z+.1
    N270 G00 Z-.115 Rapid into hole +.01 from last position
    N280 G01 Z-.250 Feed to Z-.250 at .003 IPR
    N290 G00 Z.1 Rapid out to Z+.1
    N300 G00 Z-.240 Rapid into hole +.01 from last position
    N310 G01 Z-.375 Feed to Z-.375 at .003 IPR
    N320 G00 Z.1 Rapid out to Z+.1
    N330 G00 Z1. Rapid to Z1., Safe position for next tool
    N340 M01 Optional stop
    N350 G90 G95 S1000 T3.3 M3 Start-up block for tool #3 Groove tool
    N360 G00 X-. 625 Rapid to X-.625
    N370 G00 Z-.533 Rapid to Z-.533, groove position
    N380 G00 X-.515 Rapid to safe position above .5 turned diameter
    N390 G01 X-.40 F.0015 Feed to X-.40 at .0015IPR
    N400 G00 X-.515 Rapid out of groove to X-.515
    N410 G00 X-.75 Z2.0 M05 M09 Rapid to safe Z position turn off spindle and coolant
    N420 M30 End of program
    The one issue tools cutting from the front side and back side of the part. Where BobCAD would only program from 1 side.... As far as the tool calls I do not see an index move for the tool position. Instead I see a tool number and offset.
    Documentation:
    T Tool number address
    This a number between T1.1 and T32.32 that is used to specify the tool required.
    The format for this number is T12.12 The 1st 2 digits are for the tool plate position of the tool.
    This number indicates the location on the tool plate that the tool is at.
    T12.12 The 2nd 2 digits are for the Geometry and wear offset to be applied to the tool selected.
    In normal operation the 1st 2 digits are the same as the 2nd 2 digits T12.12
    Al DePoalo
    Mar 2012
    1570
    Tool Offsets,
    Ok with the control and setup the tool offsets are saved on the machine ( as expected) When you call a Tool number and offset there is not moment that happens. Un like a turret late that would advance the next tool to a cutting position, in this case there is no movement the machine makes when a tool is called.
    So
    If you have 3 Tools and you wanted them to go to X1 Z0
    T1.1
    G00 X 1
    G00 Z0
    This would bring tool 1 to X1 Z0
    T2.2
    G00 X1
    G00 Z0
    This would bring tool 2 to X1 Z0
    T3.3
    G00 X1
    G00 Z0
    This would bring tool 3 to X1 Z0
    This is because the tool " zero point" is saved as a tool offset.
    The program would need to be written so the machine would move in X first to advance to the tool station, then in Z...
    Now where it getting a little strange is when you cut on the front or back side the the lathe.
    BobCAD always program on just one side the the lathe. Where using Gang tooling you can cut in + X or - X.
    I think in order to post code to support x+ and X - there would need to be a script written that will reverse the value of the X if and when needed.
    This is what I have come up with so far. Any thoughts...
    Al DePoalo
    Mar 2005
    368
  17. #17
    Mar 2012
    1570
    ok,
    So what I've found is the negative X movement can be posted with out a script.
    I have a simple file for everyone to look at and are interested in feed back.
    hosting images
    Code:
    % ######,MX,
    ; (BEGIN PREDATOR NC HEADER)
    ; (MCH_FILE=LATHE.MCH)
    ; (LTOOL T1 M1 S3 O15. I.25 A60 C.0156 H0. D0. N1)
    ; (LTOOL T3 M3 S9 O0. I.125 A0 C.0156 H.5 D0. N3)
    ; (SCYL S3 X0 Y0 Z-4. D1.5 L4.)
    ; (HCYL S3 X0 Y0 Z-4. D0. L4.)
    ; (END PREDATOR NC HEADER)
    N1 G90 G97 G95 F.015
    N2 M9
    N3 T1 D1
    N4 G92
    N5 M3
    N6 G0 X1.3 Z.25
    N7 G1 Z-3.2306
    N8 G1 X1.3171 Z-3.2449
    N9 G3 X1.32 Z-3.25 I-.009 K-.0053
    N10 G1 Z-4.
    N11 G0 Z.25
    N12 G0 X1.1
    N13 G1 Z-3.0639
    N14 G1 X1.3 Z-3.2306
    N15 G0 Z.25
    N16 G0 X1.02
    N17 G1 Z-2.9972
    N18 G1 X1.1 Z-3.0639
    N19 G0 X2.
    N20 G0 Z1.
    N21 M9
    N22 T3 D3
    N23 D3
    N24 G92
    N25 M3
    N26 F.015
    N27 G0 X-1.4077 Z-2.4209
    N28 G1 X-.5713
    N29 G0 X-1.4077
    N30 G0 Z-2.5209
    N31 G1 X-.5713
    N32 G0 X-1.4077
    N33 G0 Z-2.5544
    N34 G1 X-.5713
    N35 G0 X-2.
    N36 G0 Z1.
    N37M9
    N38 M5
    N39 M30
    I can see the tool call and offset would need to be changed from
    T3 D3 to T3.3
    picture hosting
    Using a 4 would normally be for ID cutting, but in this case we can use it for -X features.
    So far I can't tell why the software wouldn't be able to post for gang tooling lathes..........
    Attached Files Attached Files
    Al DePoalo
  18. #18
    Mar 2012
    1570
    1 G90 G97 G95 F.015
    N2 M9
    N3 T1 D1
    N4 G92
    N5 M3
    N6 G0 X1.3 Z.25
    N7 G1 Z-3.2306
    Looking at this block, we would also have an issue as it's not a good idea to move both the X and Z at the same time to the art position. As it would be more likely to cause a crash.
    The initial position should move in X first than Z, which should be a simple post tweak.
    Al DePoalo
  19. #19
    Mar 2012
    1570
    Sample X + OD Rough
    Code:
    % ######,MX,
    ; (LTOOL T1 M1 S1 O27.5 I.25 A35 C.0156 H0. D0. N1)
    ; (SCYL S3 X0 Y0 Z-7.0866 D2.9528 L7.0866)
    ; (HCYL S3 X0 Y0 Z-7.0866 D0. L7.0866)
    N1 G90 G97 G95 F5.
    N2 M9
    N3 T1 D1
    N4 G92
    N5 M3
    N6 G0 X2.2327
    N7 G0 X2.0528 Z.039
    N8 G1 Z-4.6668
    N9 G1 X2.2528
    N10 G0 Z.039
    N11 G0 X1.8528
    N12 G1 Z-4.6668
    N13 G1 X2.0528
    N14 G0 Z.039
    N15 G0 X1.6528
    N16 G1 Z-4.6667
    N17 G1 X1.6557 Z-4.6668
    N18 G1 X1.8528
    N19 G0 Z.039
    N20 G0 X1.4528
    N21 G1 Z-4.6428
    N22 G1 X1.4635 Z-4.6458
    N23 G1 X1.5138 Z-4.6552
    N24 G2 X1.531 Z-4.6581 I.0238 K.058
    N25 G1 X1.5868 Z-4.6641
    N26 G2 X1.6063 Z-4.6651 I.0235 K.1914
    N27 G1 X1.6528 Z-4.6667
    N28 G0 Z.039
    N29 G0 X1.2528
    N30 G1 Z-4.5466
    N31 G1 X1.2662 Z-4.5589
    N32 G2 X1.2742 Z-4.5649 I.0238 K.0116
    N33 G1 X1.3084 Z-4.5876
    N34 G1 X1.353 Z-4.6099
    N35 G1 X1.4058 Z-4.6299
    N36 G1 X1.4202 Z-4.6339
    N37 G1 X1.4528 Z-4.6428
    N38 G0 Z.039
    N39 G0 X1.0528
    N40 G1 Z-1.2489
    N41 G1 X1.0845 Z-1.2671
    N42 G1 X1.1197 Z-1.2934
    N43 G3 X1.1261 Z-1.2989 I-.0194 K-.0149
    N44 G1 X1.1452 Z-1.3183
    N45 G1 X1.1552 Z-1.3288
    N46 G1 X1.1732 Z-1.3553
    N47 G3 X1.178 Z-1.363 I-.0698 K-.0257
    N48 G1 X1.1859 Z-1.3829
    N49 G3 X1.1913 Z-1.3979 I-.4241 K-.0844
    N50 G1 X1.1957 Z-1.4311
    N51 G1 Z-4.4368
    N52 G1 X1.1996 Z-4.4645
    N53 G2 X1.2019 Z-4.4732 I.0389 K.0007
    N54 G1 X1.2115 Z-4.4952
    N55 G1 X1.2152 Z-4.5029
    N56 G1 X1.235 Z-4.5294
    N57 G2 X1.2401 Z-4.535 I.0249 K.0079
    N58 G1 X1.2528 Z-4.5466
    N59 G0 Z.039
    N60 G0 X.8528
    N61 G1 Z-1.18
    N62 G3 X.8659 Z-1.1825 I-.017 K-.0543
    N63 G1 X.9227 Z-1.1965
    N64 G3 X.9404 Z-1.2022 I-.067 K-.1146
    N65 G1 X.9793 Z-1.2152
    N66 G3 X.9883 Z-1.2186 I-.013 K-.0218
    N67 G1 X1.0344 Z-1.2388
    N68 G3 X1.0422 Z-1.2428 I-.0225 K-.0257
    N69 G1 X1.0528 Z-1.2489
    N70 G0 Z.039
    N71 G0 X.6528
    N72 G1 Z-1.1611
    N73 G1 X.6557
    N74 G1 X.7039 Z-1.1627
    N75 G3 X.7292 Z-1.1637 I-.0089 K-.1876
    N76 G1 X.7791 Z-1.1687
    N77 G3 X.8032 Z-1.1716 I-.0107 K-.07
    N78 G1 X.8528 Z-1.18
    N79 G0 Z.039
    N80 G0 X.6051
    N81 G1 Z-1.1611
    N82 G1 X.6528
    N83 G0 X6.
    N84 G0 Z1.
    N85M9
    N86 M5
    N87 M30
    Sample X- OD Rough
    Code:
    % ######,MX,
    ; (LTOOL T1 M1 S1 O27.5 I.25 A35 C.0156 H0. D0. N3)
    N1 G90 G97 G95 F5.
    N2 M9
    N3 T1 D1
    N4 G92
    N5 M3
    N6 G0 X-2.0611
    N7 G0 Z.039
    N8 G1 Z-4.6668
    N9 G1 X-2.2211
    N10 G1 X-2.2351 Z-4.6682
    N11 G2 X-2.2415 Z-4.6701 I.005 K-.0126
    N12 G1 X-2.2467 Z-4.6718
    N13 G2 X-2.253 Z-4.6754 I.0052 K-.0078
    N14 G1 X-2.2579 Z-4.6791
    N15 G1 X-2.2611 Z-4.6868
    N16 G1 Z-6.4782
    N17 G0 Z.039
    N18 G0 X-1.8611
    N19 G1 Z-4.6668
    N20 G1 X-2.0611
    N21 G0 Z.039
    N22 G0 X-1.6611
    N23 G1 Z-4.6668
    N24 G1 X-1.8611
    N25 G0 Z.039
    N26 G0 X-1.4611
    N27 G1 Z-4.6451
    N28 G1 X-1.4646 Z-4.6461
    N29 G1 X-1.5066 Z-4.6539
    N30 G3 X-1.5289 Z-4.6578 I-.0589 K.1488
    N31 G1 X-1.5751 Z-4.6629
    N32 G3 X-1.5978 Z-4.6648 I-.0157 K.0583
    N33 G1 X-1.6557 Z-4.6668
    N34 G1 X-1.6611
    N35 G0 Z.039
    N36 G0 X-1.2611
    N37 G1 Z-4.5543
    N38 G1 X-1.2652 Z-4.558
    N39 G3 X-1.2742 Z-4.5649 I-.0322 K.0161
    N40 G1 X-1.3083 Z-4.5876
    N41 G1 X-1.355 Z-4.6109
    N42 G1 X-1.4001 Z-4.6277
    N43 G3 X-1.4195 Z-4.6337 I-.0326 K.0419
    N44 G1 X-1.4611 Z-4.6451
    N45 G0 Z.039
    N46 G0 X-1.0611
    N47 G1 Z-1.2537
    N48 G1 X-1.0845 Z-1.2671
    N49 G1 X-1.1197 Z-1.2934
    N50 G2 X-1.1261 Z-1.2989 I.0194 K-.0149
    N51 G1 X-1.1452 Z-1.3183
    N52 G1 X-1.1552 Z-1.3288
    N53 G1 X-1.1732 Z-1.3553
    N54 G2 X-1.178 Z-1.363 I.0698 K-.0257
    N55 G1 X-1.1859 Z-1.3829
    N56 G2 X-1.1913 Z-1.3979 I.4241 K-.0844
    N57 G1 X-1.1957 Z-1.4311
    N58 G1 Z-4.4368
    N59 G1 X-1.1996 Z-4.4645
    N60 G3 X-1.2019 Z-4.4732 I-.0389 K.0007
    N61 G1 X-1.2115 Z-4.4952
    N62 G1 X-1.2152 Z-4.5029
    N63 G1 X-1.235 Z-4.5294
    N64 G3 X-1.2417 Z-4.5364 I-.0341 K.0119
    N65 G1 X-1.2611 Z-4.5543
    N66 G0 Z.039
    N67 G0 X-.8611
    N68 G1 Z-1.1815
    N69 G1 X-.9159 Z-1.1949
    N70 G2 X-.9323 Z-1.1995 I.0182 K-.0419
    N71 G1 X-.9727 Z-1.213
    N72 G1 X-.9865 Z-1.2178
    N73 G1 X-1.0324 Z-1.2379
    N74 G2 X-1.0419 Z-1.2427 I.0196 K-.0244
    N75 G1 X-1.0611 Z-1.2537
    N76 G0 Z.039
    N77 G0 X-.6611
    N78 G1 Z-1.1613
    N79 G1 X-.7056 Z-1.1627
    N80 G2 X-.7292 Z-1.1637 I.0077 K-.1648
    N81 G1 X-.7791 Z-1.1687
    N82 G2 X-.8032 Z-1.1716 I.0107 K-.07
    N83 G1 X-.8611 Z-1.1815
    N84 G0 Z.039
    N85 G0 X-.6051
    N86 G1 Z-1.1611
    N87 G1 X-.6557
    N88 G1 X-.6611 Z-1.1613
    N89 G0 X-6.
    N90 G0 Z1.
    N91M9
    N92 M5
    N93 M30
    Al DePoalo
  20. #20
    Apr 2008
    1577
    Can you do both X- and X+ turning in the same setup with different tools? Looks like you got this under control here Al
Page 1 of 2 12
  1. basic question for rookie
    By bigvinney in forum Uncategorised MetalWorking Machines
    Last Post: 07-24-2012, 09:46 PM
  2. Rookie Question...3 axis vs 4 axis controller
    By Ferrari2007 in forum DIY CNC Router Table Machines
    Last Post: 09-14-2009, 02:04 AM
  3. CNC Rookie Help!
    By aaronn in forum Haas Mills
    Last Post: 03-03-2009, 12:56 AM
  4. rookie
    By dcms in forum Community Club House
    Last Post: 03-27-2008, 06:20 AM
  5. Replies: 14
    Last Post: 03-30-2007, 12:51 PM
