603,958 active members*
1,922 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Rotary Table Interface on Fanuc OM/C: Do I need new firmware?
    inthezone Guest
    I have a Fanuc OM/C controller that has been retrofitted to an old Bridgeport II vertical mill. The controller has been set up to use 3 axis and the spindle.
    I recently came in to possession of an AG Davis rotary table that i would like to interface as a fourth axis with my Fanuc controller. Upon inspection of the box I realized that i would need the appropriate servo amplifier and servo motor. I bought servo motor and amplifier relatively identical to the ones already used in my setup.
    I am in the process of ordering cable and connectors, but I realize that I might be getting ahead of myself. The firmware (ladder logic?) of the controller is not set up for a fourth axis, although the controller itself has fourth axis buttons and a fourth axis connect on the motherboard.
    Do I have to flash the firmware, or reprogram the ladder logic to use a fourth axis? What steps am I missing?
    Dec 2003
    24260
    There is also a Option parameter that has to be purchased.
    I also sent some info in PM.
    Is this rotary axis capable of being an interpolated 4th axis or just index positioning?
    Al.
    Albert E.
  1. How do you use a rotary table?
    By ranchak in forum Uncategorised MetalWorking Machines
    Last Post: 01-31-2008, 05:30 AM
  2. rotary table
    By bulletfab in forum Haas Mills
    Last Post: 12-16-2007, 09:48 PM
  3. Cnc Rotary Table
    By BAYWATCH-TIM in forum Uncategorised MetalWorking Machines
    Last Post: 10-31-2006, 10:11 PM
  4. Useful for Rotary Table?
    By Ken Stuempge in forum Mechanical Calculations/Engineering Design
    Last Post: 02-12-2006, 04:16 PM
  5. Rotary Table Req
    By h_2_o in forum Uncategorised MetalWorking Machines
    Last Post: 02-08-2005, 08:11 PM
