603,855 active members*
3,506 visitors online*
Thread: rotate?
Results 1 to 4 of 4
    May 2005
    64
    rotate?
    I have a simple form, essentially a rectangular pocket with radiused corners drawn normal to the X/Y plane. Extruded down, (z minus).
    I'd like to rotate this pocket around X axis so that the bottom of the pocket is sloped. I'm not concerned with the resulting change to the adjacent sides, they could have the same slope, or not, It is unimportant to my project.
    When using bobcad v21, I just select the geometry, and command rotate, specify an axis and an angle. Done.
    I'm not having the same luck with alibre. An alibre tech gave a friend of mine a description of how to do this, involving drawing a new form next to the existing one, extruding the new form with draft, and constraining the new form to original one.
    Is it not possible to simply rotate an element/solid in relationship to the drawing?
    thoughts, comments?
    Jul 2004
    97
    I AM ALSO USING ALIBRE, I AM ALSO USED TO JUST MANIPULATING THE DRAWING THAT I ALREADY HAVE. I THINK ALIBRE HAS TO DO THIS BECAUSE OF THE PARAMETRIC ASPECT OF THEIR SOFTWARE. USED CADKEY AND BOBCAD FOR YEARS. THE NEW WAY OF THINKING TAKES A LITTLE GETTING USED TO.
    Jun 2006
    3063
    Not sure if this will answer the question or not, but in general a revolved sketch must not cross the axis of rotation. Does that help at all?
    If not, you might try uploading a sample file.
    Mike
    May 2006
    807
    I still use Cadkey 19
    It just plain works good
    Been doing this too long
  1. Rotate G68
    By cadman@teluspla in forum Haas Mills
    Last Post: 05-08-2008, 09:39 PM
  2. My stepmotors don't rotate....
    By Mikael in forum Controller & Computer Solutions
    Last Post: 04-23-2008, 03:06 AM
  3. rotate on axis A
    By tonyas in forum Mach Software (ArtSoft software)
    Last Post: 01-03-2008, 11:20 AM
  4. Rotate head
    By SPEEDRE in forum Benchtop Machines
    Last Post: 12-23-2007, 07:44 PM
  5. V2007 Rotate
    By TZ250 in forum BobCad-Cam
    Last Post: 10-14-2007, 06:39 PM
