603,893 active members*
3,902 visitors online*
IndustryArena Forum > CAM Software > Mastercam > rotating geometry and surfaces
Results 1 to 20 of 20
    Oct 2004
    41
    I am doing some part time work at a company using MC ver 9 and I have hit a snag.
    What I would like to know is if you have created some geometry IE: the neck of a guitar and placed surfaces on it and say you have done the back of the neck to start with but the front is also drawn and complete, how do you turn it over IE machine the rear part and then turn the drawing over 180 degrees so you can set it up for tool pathing and machining the front side of the neck without having to redraw the whole thing again???
    thanks
    cc
    Dec 2005
    93
    Easiest way for me is to go to side view. Then from the menu...
    Transform
    Rotate
    All
    Entities
    Done
    Box opens up....
    Check.... Move, 1 step, 180 deg, OK
    Part flips over in this view, go back to "top" view and now you are looking at the "bottom" of the part, available to be machined.
    Mar 2005
    988
    I'll throw this out there, but you may not get it at first if you've never used it. Orient the part to a main view (using top or front is the most common). Now using the WCS menu, you can create all of your workoffsetting for the different views. Then, depending on the machine type (horizontal, vertical or otherwise), you can control the the tool paths using the tool plane and/or construction plane.
    This simplifies programming (maybe not at first) and allows you to do a number of operations without having to constantly rotate the part, create duplicate models, a multitude of levels, etc. Plus, as you may know, rotating (or any transform operation) a part with existing toolpaths on them corrupts the toolpath. Now you have to regenerate them, but in order to be correct with your part orientation of that particular operation, you need to "un-transform" the part back to the original state.
    Read the WCS tutorial included with V9 (also through the Help Menus) and go over the Tool plane/construction plane usage. Its well worth it. Otherwise,.... do what the guy said above....
    It's just a part..... cutter still goes round and round....
    Oct 2004
    41
    I just tried what yo suggested DJPLAST but all it does is rotate the geometry around in a 360 circle with varying degrees that I input.
    Maybe I did not explain properly so here goes.
    Imagine a shoebox with geometry on the top surface and the bottom surface.
    How do I turn the box over to have the bottom surface as the top surface?
    thanks
    and to psycomill man that will take some reading and thanks as well.
    c
    Dec 2005
    93
    Go back and read and follow the steps as stated. You must move to the END VIEW for this to work. Not the TOP VIEW.
    Oct 2004
    41
    Smile
    Thanks Guy's yes I did go back and try again. I found psycomills idea a lot easier as I still had drama with your method DJ but thats just my lack of experience in this sector of MC not having used surfaces before this job.
    Anyway the boss is happy, job done and now for some weekend.
    Once again many thanks to you both.
    cc
    Dec 2006
    247
    I think dj's method is way easier. goto side view make sure your cplane and gview are set to side plane and rotate the part around origin. then apply tool paths, easy. If you go to screen configure you can set it up so when you change views it changes cplane. I'm kinda thinking this is a bogus post how could you not follow dj's post and follow psychomills???
    Dec 2006
    247
    HuH,
    Move geometry to origin.
    Dec 2005
    93
    joecnc, I forgot to tell flinty to make sure that the CP and the Gview were set the same. Can't figure out how come he's having so much trouble. Thanks for the extra help.
    Oct 2004
    41
    DJ trust me this was a real problem,
    What I also did was go to http://www.eapprentice.net/lesson_2.html
    check out the "free " lessons on WCS it's in X but I worked out how it could be done in v9
    thanks again
    cc
    Flinty,
    Check this outthis might help http://www.cad2cam.net/zany.html
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
    Dec 2006
    247
    wow steve that was awesome I can't believe you put that much effort into a post cheers to you.
    Joe
    Dec 2006
    247
    Steve,
    I've got a real complex part to machine it was supposed to be a casting if I shoot it to you can you give me an idea of cost I drew it up and made a solid out of it but I'm starting to think it would be too expensive to machine instead of cast. I can have it converted to mc9 or solidworks I drew it up in autocad but I have some conections. I think it will take too many ops to make it feasable for a hog out but the company I work for thinks it can happen. I just want some advice Thanks
    Joe
    Joe,
    I like to help when I have time, I did this for someone who was having problems with wcs, but it has some other steps in it that can be helpful.
    www.cad2cam.net
    Apr 2003
    3578
    Joe did you get an answer to the part you are talking about? willing to look and advize.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Dec 2006
    247
    heres a pic of it it's heat treated ss 5.5" dia i'm concerned with the port and how long its going to take to rough and finish. Thanks
    Joe
  17. #17
    Oct 2004
    41
    Steve,
    thanks a lot for the camtasia presentation it is awesome.
    If you do not already do this for a living, you have just found your niche,
    Presentations like this should cost money, thank you.
    cc
  18. #18
    Thanks flinty I do this for a living mostly on-site though Joe send me your part.
    [email protected]
    www.cad2cam.net
  19. #19
    Mar 2005
    81
    I use levels and associate the geometry with that level. to rotate I use c-plane, entity, select x,y use next till you get the view you want, and that gives you a number. plug the number in and say you want it to be top view, origin. the geometry says with the view.
  20. #20
    Joe,
    I sennt a private message.
    Steve
    www.cad2cam.net
    www.cad2cam.net
  1. Rotating ballnut?
    By cncuser1 in forum Linear and Rotary Motion
    Last Post: 09-12-2014, 10:31 AM
  2. spindle not rotating
    By tiwanags in forum Commercial CNC Wood Routers
    Last Post: 09-11-2007, 01:49 PM
  3. Geometry from NC
    By rherman in forum BobCad-Cam
    Last Post: 09-21-2006, 01:10 PM
  4. Rotating nut plan/Diagram
    By tpworks in forum Linear and Rotary Motion
    Last Post: 07-27-2006, 05:14 PM
  5. Rotating nut conversion?
    By Corvus corax in forum Linear and Rotary Motion
    Last Post: 12-01-2005, 01:22 AM
